10-08-2017, 10:00 AM | #1 |
Newbie Join Date: Jan 2017 Location: North Alabama
| Need a pinion gear
My son installed a 35t motor into his E10. He would not wait on me to help. He ended up stripping out the set screw on the pinion gear. I thought I had had planned ahead and bought some steel redcat at gears but they are for a different model and don't fit. Will try local store tomorrow,but they don't carry Redcat. What can I look for that will fit? Thanks for any input.
10-08-2017, 01:21 PM | #2 |
| Re: Need a pinion gear
If i remeber the e10 uses the 32p pinnion and spur gears u can use any combo set up for a scx10 or wraith in what ever size or pitch you want i went a bit higher on the pinnion tooth count so it goes a little bit faster
10-08-2017, 02:21 PM | #3 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
It's 48p. Stock gear is 14t. Go with fewer teeth for slower speeds or more for faster. I believe the largest pinion that will fit with a stock vehicle is 17T and the smallest 10T. Apart from this, watch out for pinion gears that have a large base (where the set screw fits). I bought a hot racing one that didn't fit because this area was too big.
10-09-2017, 07:54 PM | #4 |
Hobby shop was able to fix me up with a steel replacement pinion.
Need a pinion gear - Similar Threads | ||||
pinion gear and steel gear upgrade question (in the middle of installing, pleasehelp) | Sloalty | Redcat Crawlers | 3 | 05-23-2016 08:48 PM |
Pinion gear and ring gear mesh question | flyboy320 | Axial Wraith | 18 | 01-09-2016 02:41 PM |
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
