Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Gen 7 Pro front negative camber issue
Old 04-11-2019, 03:59 PM   #1
Default Gen 7 Pro front negative camber issue
Any other Gen 7 Pro owners have extreme amounts of front negative camber? I have all original front plastic components but it just seems like the top of the tires tip in way further than they should and I can't figure out any way to adjust it. It's bad enough that the front left tire is contact the steering tie rod and rubbing a "groove" in the tire. It is this way on both front tires, I have disassembled and reassembled the front end and everything is tight and assembled correctly. The truck is less that a week old and I live in Nebraska so it hasn't really seen any "crawling" other than over my children and grass driving. Any suggestions how to alleviate this or is it just the way they are. I also notice that none of the wheels turn "true" they all look like the wheels are bent when driving on flat ground and 50% throttle.
tmoneymr2 is offline   Reply With Quote
Gen 7 Pro front negative camber issue - Similar Threads
Negative camber robertjpjr Axial SCX10 II 24 10-09-2022 04:30 AM
SCX10 Camber or Toe or something steering issue. webbl19 Axial SCX-10 10 05-14-2017 07:41 PM
Negative Camber with stock settings amped up Axial Yeti 9 11-19-2015 04:00 PM
Installed asiatees c hubs, now my camber is negative? woodsman541 Newbie General 18 03-13-2015 06:17 AM
Rear negative camber? frdtrkguy General Crawlers 1 12-30-2007 08:30 AM
