05-06-2020, 06:56 AM | #1 |
Newbie Join Date: May 2020 Location: South Lyon
| Looking for Wendigo steering upgrades
Hi I am looking for Wendigo steering upgrades currently I am having a problem with the front right passenger drag link end the Drag link is steel and the ends are plastic are plastic so it is easy to strip them out I would like to replace all the plastic ends if possible I saw a video before I bought the car and I thought it said gen 8 Parts would work
05-06-2020, 07:48 AM | #2 |
| Re: Looking for Wendigo steering upgrades
redcat uses tearable rod ends the gen8 has a slightly narrower front end so you cant use.the steerting parts but for $2 you can buyna stick of 5/32 all thread and then go to the auto parts store and pick up a sitck of breakline tubing then off too the local hobbie store and pick up some quality plastic rod ends dont get the metal ones you will kick yourself down the road or wait for redcat to sell replacement parts and keep having the same problem |
05-09-2020, 06:20 AM | #3 |
Newbie Join Date: Mar 2020 Location: Newcastle
If you glue the threads they wont strip. I used tire glue on some. Other I used gorilla glue or regular ca. Even if they strip before gluing more often then not you can use the stripped one just by gluing it and it won't strip or pull off again. I bent draglinks an tierods with the glued plastic links. And the links never budged. I would also stay away from metal. And club 5, traxxas links. The club 5 and traxxas links will break. The Redcat plastic links take alot more beating. And are more forgiving in my experience |
05-12-2020, 05:35 AM | #4 |
Rock Stacker Join Date: Jan 2015 Location: westminster
Make sure none of the screws are over tightened. I found one on my gen 8 that was, and it wouldn't give me full steering on both sides. Also, check clearance between the diff cover and tie rod.
Looking for Wendigo steering upgrades - Similar Threads | ||||
Wendigo is a go. | mgputer | Redcat Crawlers | 77 | 05-07-2022 10:09 AM |
wendigo upgrades? | michigan hooigan | Newbie General | 1 | 09-12-2020 11:29 AM |
SCX10 iii or Wendigo | AK KRAWLER | General Crawlers | 11 | 03-22-2020 09:23 PM |
Steering upgrades? | Tayrob | Axial SCX-10 | 8 | 01-09-2013 03:12 PM |
Steering Upgrades???? | bigstu | Axial XR10 | 7 | 09-17-2010 07:27 PM |
