04-24-2014, 08:58 PM | #1 |
Pebble Pounder Join Date: Jun 2010 Location: victorville
| tires size what size is the red cat rs10
can someone tell me the size please thank u guys
04-24-2014, 09:23 PM | #2 |
RCC Addict Join Date: May 2011 Location: at home
| Re: tires size what size is the red cat rs10
2.2 is the size this refers to the inside diameter of the tire normally about 2 inches wide and about 5 inches tall for rock crawling some are taller, up to 5.5 and a couple almost 6 inches tall the most popular seems to be the hot bodies rover tires with the white dot, the pink dot are way softer but a bit smaller in diameter the sedonas are also good as are the panther leopards. if you have money to spend, the voodoos are maybe the best tires so far the stock tires use a stiffer rubber compound than what is needed, even taking out the foams and cutting up the treads (siping) only help a little bit. at about 20.00 a pair of rovers you cannot go wrong |
tires size what size is the red cat rs10 - Similar Threads | ||||
Crawling at Mchugh Creek Alaska - Red Cat Rockslide RS10 | Robotron | Videos! | 0 | 06-20-2013 06:58 PM |
Red Cat RS10 Or Maxstone 10 for new crawler | stompjrkz400 | Newbie General | 21 | 12-16-2011 12:35 PM |
New to Red Cat,Best Tires To Buy? | carolina928 | Redcat Crawlers | 15 | 06-21-2011 09:24 AM |
