Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Everest 10 steering Bec?
Old 01-20-2017, 03:29 AM   #1
Default Everest 10 steering Bec?
Just ordered a 30kg steering servo. It might sound like overkill, but I don't want to be buying a new one every week, or wanting for more later if the set-up changes. A friend suggested I'll need a Bec for it now. As a newb, I don't really understand the lectrical side yet, so.... what kind of Bec do I need? Where do I chop in? Tia.
Disco Stu III is offline   Reply With Quote
Old 01-20-2017, 05:44 AM   #2
Default Re: Everest 10 steering Bec?
Is the new servo a high voltage servo?
Smokin' Joe is offline   Reply With Quote
Old 01-20-2017, 06:36 AM   #3
get a castle bec,
you really dont need one though imho
stump1 is offline   Reply With Quote
Old 01-20-2017, 06:39 AM   #4
It get the full potential out of your new servo and take some stress off of your esc. Yes a bec should be installed.
Here is a link to a plug and play set up. Only thing is might have to change battery ends on battery and esc to dean's plug (another good idea anyways) to get it to work.
HeyOK No Brainer BEC - Adjustable
hillbillyrc is offline   Reply With Quote
Old 01-20-2017, 08:28 AM   #5
At that torque output it is likely a high voltage servo. You could also use a small 2S lipo to power the servo instead of a BEC, if that's the case.
Old 01-21-2017, 04:48 AM   #6
Yes, it is a "hi voltage" unit. The lipo upgrade will have to wait a few months sadly. Deans plugs hopefully installed tomorrow. Thanks everyone.
Old 01-22-2017, 08:08 PM   #7
Although, after adding deans plugs yesterday, I think I may have inadvertently swapped polarity on my wall charger, the Oem one. I think the neg cable usually has the writing on it, but I have put it on pos. another job. On a plus note, I just noticed a dhl card in my mail box, servo is here already. mint. The daughter is going to be stoked. On a side note, am thinking of limiting straps for those days when you want to keep 5hit to scale, or have a body that would otherwise rub on the tyres, owing to ridiculous axle articulation. Anyone else tried similar, or just bitten the bullet, gone back to ladder frame etc?
Old 01-23-2017, 05:25 AM   #8
I don't think the amount of articulation the E10 has when stock is necessary or all that beneficial for crawling. I don't use limiting straps, but I did add some nylon spacers under the shock body to limit travel.
Old 01-23-2017, 07:39 AM   #9
thats what i did works just fine
Old 01-24-2017, 12:10 AM   #10
Okay, thanks. I got fuel ho's and nylon tubing here somewhere. The current position of the body looks more like the mud bogger type thing. I 'd rather something like the 'lux in the pic.
Everest 10 steering Bec? - Similar Threads
FYI-Everest 10 and axial steering bushings not equivalent Smokin' Joe Redcat Crawlers 1 10-03-2016 03:13 PM
Faster motor and steering knuckles for the Everest 10. escrawler Redcat Crawlers 6 12-07-2015 08:13 PM
Cc bec vs steering issues? SwampDawg Electronics 18 11-04-2010 05:36 PM
BEC and Steering Mystery Harvo Electronics 3 08-01-2009 10:51 AM
