01-12-2015, 03:50 AM | #21 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
| Re: Bitter End's 1/6 Scale Garage
Clock is killer, the mini monitor is very cool. Very creative.
01-12-2015, 11:12 AM | #22 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
Love the monitor other than the toes......... Not a foot person ......... I am working on a wall mount for an iPod that's going up in mine in the second floor, but I may have to do a pc as well ( if you don't mind me stealing your idea) -Dan |
01-12-2015, 10:07 PM | #23 | |
Quarry Creeper Join Date: Aug 2013 Location: Graham, Washington
| Re: Bitter End's 1/6 Scale Garage Quote:
My toes on a mexican beach, looking out across the sea of cortez. Later gators I'll be off grid for a few days. | |
01-25-2015, 11:23 PM | #24 |
Well, back from a little R&R down in Baja and I've been chompin at the bit to get back to finishing a few projects. In between unpacking the suitcases I cut a sheet of plexiglass for the window and set it in place. I'll finish trimming it out tomorrow, but threw a little sunset in the back to give me a garage with a view It does look very cool back-lit. |
02-16-2015, 03:57 AM | #25 |
A little more progress this week. Rollin in the box A little 1/6 scale of the 1/6 scale! Yea it is a working RC very cool to see it drive around him when he has a TX in hand. I'll shoot a video of it this week. Wheelin the torch over. I got the bottles last year off ebay but made the cart. I made some run-of-the-mill tire and wheels for it but ran into these little mags I had from a project 15 or 20 years ago and tried um on for size. I have to find a spot for my roached bullet ridden hwy 66 sign. In case you were wondering what the hole to the right of the window was for. |
02-23-2015, 02:51 PM | #26 |
Working on an air compressor today. I had a mini compressor from a previous project, but needed to size things up for this build. The main part (the tank) was easy enough using a water bottle. Kind of hard to make out the details of the top and air pipe, but here it is anyway. Roughing out a base support. Compressor and regulator mounted, wired and plumbed. This will fit in nicely into the corner and plumbed into the air system. I'll come up with a decal and data plate to finish it off. |
02-23-2015, 06:41 PM | #27 |
Quarry Creeper Join Date: Mar 2011 Location: over there...
Nice!
02-24-2015, 05:11 AM | #28 |
| Re: Bitter End's 1/6 Scale Garage |
03-01-2015, 01:16 PM | #29 |
I needed to scale up a welder, so I started with a welding cart. I searched around the interwebs for one to loosely base one off of. To scale up the ground clamp I made it similar to the jumper cables I made last year (cutting down some alligator clips and adding handles. A made a new welding gun, installed the retaining chain for the gas bottle and pieced it all together. I had originally painted the buzz box blue and was going to hang some Miller logos on it, but the blue turned out too dark, so I stripped it and hit it with the red and a Lincoln Electric patch. |
03-01-2015, 01:23 PM | #30 |
I needed to have a welding helmet in the mix and went with a rough design of this style painted red. This was my first effort at the head strap. In the end I opted to redesign it and screwed it in place directly. |
03-01-2015, 03:06 PM | #31 |
Very nice work, temple fasteners, I would have never thought of that! Awesome details! The safe door is cool.
03-04-2015, 04:27 AM | #32 |
Time to slide in a couple of work benches. I picked up some flat bar and round stock at the local hardware store and cobbled together a two different length workbenches. I buffed out the bench tops, I'm not sure if I will leave them bare or paint them. In the pacific northwest the steel has a tendency to rust if left unprotected. |
03-04-2015, 03:59 PM | #33 |
I vote for clear coat and leave raw, just like a metal working - work bench should look. Benches turned out killer!
03-04-2015, 04:16 PM | #34 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
You could always spray clear over them, they look to good raw to paint.
03-05-2015, 03:42 AM | #35 |
So the wife came out to the garage yesterday and took a look around. What are building out here? I see, what are you going to do with it when you're done.... Women.... |
03-05-2015, 03:53 AM | #36 |
Easy answer.....I thought I would place it on the dinning room table so I can share it with friends and family! And oh......it's never going to be done.
03-09-2015, 02:04 AM | #37 |
| Re: Bitter End's 1/6 Scale Garage That's the beauty of my wife, she would give me an "are you serious" look, shrug it off and accept the change of scenery. |
03-09-2015, 02:08 AM | #38 |
I ran across some poplar down at the local hardware store, it looked pretty close to the door opening that I had framed in (less cuts +++). As luck would have it, it was a perfect fit! After a few one eyed squints with my thumb in the way it started to take shape. Poplar is a pretty soft wood so chiseling out a spot for the hinges to live was easy enough... measure once, cut twice! I test fit of the trim pieces and it's ready to put together. Lastly, I clamped everything up so the glue will dry and all of the pieces will stay put. I left it dry overnight and unclamped it the next morning. I think it will work out fine. I had zero room to spare sliding it into place. Here is a shot from the outside of the garage. I need to decide on the door knob yet so I didn't paint or stain it, or nail it in for that matter. I'll have to pull it back out for the finish work. |
03-09-2015, 02:18 AM | #39 |
I was also able to finish off the safe tonight (one more thing on a growing list to cross off)! I concealed the safe with a hinged cork-board; using a thin piece of metal glued to the back of the cork-board and strong magnets on the backside of the wallboard. It stays closed tight til your swing it open. |
03-09-2015, 02:25 AM | #40 |
I've been toying around with different garage art for a while, so tonight I printed some up and scaled it down to the right size. I wanted it to be a little more than taping a picture to the wall, so I mounted them to some .060 styrene. I mounted a few pieces up on the wall, I hope it works out because that 3M industrial two sided tape is there for keeps, it doesn't like to give up anything that you've attached it to. |
Bitter End's 1/6 Scale Garage - Similar Threads | ||||
Bitter End's 41 Willy's | Bitter End | Videos! | 0 | 09-28-2014 03:49 AM |
new job is bitter-sweet | BigSki | Chit Chat | 24 | 12-12-2011 08:57 PM |
Are these ball end's any good? | Crawla | General Crawlers | 12 | 08-16-2004 10:21 PM |
