01-29-2012, 04:34 PM | #61 |
Pebble Pounder Join Date: Oct 2010 Location: san diego
| Re: New Quicksand 8274 Winches
Man those winches look like they have got some power behind them!
02-01-2012, 12:37 AM | #62 |
Rock Stacker Join Date: Jul 2008 Location: way behind
| Re: New Quicksand 8274 Winches Welcome. Thanks very much, glad your happy with it. They do pull pretty good, It's an impressive little servo hiding in there. That's one of the reasons they're a bit spendy. |
02-01-2012, 06:23 PM | #63 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
how many if any are left?.....
02-01-2012, 10:13 PM | #64 |
RCC Addict Join Date: Oct 2005 Location: rite here all along
I think I'm on the list somewhere just not sure where |
02-02-2012, 12:53 AM | #65 |
Rock Crawler Join Date: Jun 2011 Location: Vancouver
well, I talked to Neil(QUICKSAND) few times to figure out how I need to do with this winch after I received this winch three weeks ago. and here are what I did with my QS 8274 winch. first, u have to take out the plastic black cover from winch. and drill a small hole on the cover to lead those two wires from motor second, solder two wires on that motor (I got a broken 3racing winch, so I cut out the wires and solder it on my QS Winch ) then put that cover back to winch, and lead those two wires out PS: make sure u don't drill a big hole, otherwise the motor will get dirt if u run in the mud or water By the way, I am running with heyok's standard winch controller, and it works pretty well so far hope these info help you guys..... I really want to see how people play with this winch (how to wire up with controller and what is the best way to run with this winch in order to get max. torque) Last edited by rcscaler; 02-03-2012 at 01:39 AM. |
02-02-2012, 03:27 AM | #66 |
I wanna be Dave Join Date: Nov 2005 Location: Here
I'm on a list also... |
02-02-2012, 08:48 PM | #67 |
hold on....this winch isnt plug in play? Whats up with drilling and soldering and dremeling and gluing and mounting and ing.....???
02-02-2012, 09:13 PM | #68 | ||
| Re: New Quicksand 8274 Winches Quote:
Read newb........... Quote:
02-02-2012, 09:14 PM | #69 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
Ok so I took my cover off to wire it today. What is the little metal pipe type pole soldered to the outside of the motor case? I'm assuming it doesn't get a wire soldered to it but not sure right now. Thanx
02-02-2012, 09:40 PM | #70 | |
If you are going to use the servo control board then the black wire gets soldered to that tab. | |
02-03-2012, 02:21 AM | #71 | |
(Reading) I got it! Nothing too hard to work on....I'd do some pretty homo stuff to get one of these winches. I'd build a rig AROUND this winch. | |
02-03-2012, 02:45 AM | #72 | |
You are on the list, near the end of the next run. | |
02-03-2012, 05:52 AM | #73 |
I plan on running a b1r to power this, so I'm assuming I use the +/- tabs. Thanx chris!
02-03-2012, 08:46 AM | #74 | ||
This winch is worth building a rig around. Quote:
Thanks for posting that rcscaler. | ||
02-03-2012, 04:52 PM | #75 |
thanks Grizzly4x4 I tried my best to post this info, but please edit it if there were something wrong |
02-04-2012, 06:51 PM | #76 |
Quarry Creeper Join Date: Jan 2011 Location: Hurricane
Can you tell me where I am on the list? And when I can expect to have it shipped? Thank you, can't wait to get it.
02-04-2012, 08:00 PM | #77 |
| Re: New Quicksand 8274 Winches Yes, thanks David. And thanks for making that little change for me. By the way.... did your hex wrenches arrive yet? I'm working now on trying to get a few of the parts I have the least of done next, and I think you're 2nd on the next batch. If that's the case, you may be looking at a few weeks. If you want to send me an email, we can confirm this.... I don't have everyone's RCC name matched up with their name on my list. |
02-06-2012, 07:38 AM | #78 |
neil, i think that having that option to mount the fairlead to the bottom of the spool support mount would b a great option. This would allow us to not have a metal tab on the bumpers of our rigs and allow this bad ass winch to be more visable!!! just having a tapped hole like the other side only on the bottom, leaving it as close to the 1:1 8274 would be great. thanx for considering that option. |
02-06-2012, 07:44 AM | #79 |
Neil, Can you tell me where I am on the list??? I'm having trouble sleeping... |
02-06-2012, 08:17 AM | #80 | |
yeah...I agree something like these..... Quote:
