04-28-2013, 10:02 PM | #301 |
| Re: DLUX super build No worries...it was just my curiosity getting the best of me. I've always hated the THUD you get when the rear trans cases finds a rock to get hung on...simply because I know it typically causes a problem with losing a critical line or having to back off and reposition. When I first saw the design of your rear case I immediately thought of my Super and how nice it'd be to have everything tucked up nice and tight to the tubes.
04-28-2013, 10:17 PM | #302 |
Yeah, well great. I am going to be up all night figuring if I should have went with the rear cases or not. |
04-28-2013, 10:41 PM | #303 | |
Quarry Creeper Join Date: Dec 2012 Location: Spokane Valley
| Re: DLUX super build Quote:
04-28-2013, 11:00 PM | #304 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
I love that chassis...it's tiny!!!!!! The rest is pretty cool too....... :-) |
04-28-2013, 11:14 PM | #305 |
Rock Crawler Join Date: May 2012 Location: Australia
Dlux. With these cvds your your making. What's the shaft diameter? Would they fit in bully lockers/gearboxes? I've done 14x8 bearing mod on my super, made my own knuckles to fit the scx10 chubs. I'm just looking at an option of different cvds for more steering, plus I've broken a few cvd pins. So I'm looking at beefing them up. |
04-29-2013, 10:27 AM | #306 | ||
You did a 14x8 bearing mod? Shoot, I wish I would have known somebody else did it a long time ago. Did you run a 3.5mm wide or 4mm wide bearing? | ||
04-29-2013, 05:32 PM | #307 | |
Can you tell me the make anyway? Might be able to sort something out. I didn't do the 14mm bearing mod ages ago. I'd say 3 weeks or so. I've still not ran the car with the mod. I used 2 bearings 4mm wide. Since I was making my own knuckles I made the bearings mount like the stock ones. Plus I only found 4mm bearings which is to wide to mount on the bully stub. | |
04-29-2013, 09:08 PM | #308 |
The shafts are Ofna brand. There are a lot of them out there in different sizes, but none that I have found in different diameters. You dont have a build thread do you? If not, it sounds like you need one. Last edited by Erik D_lux; 04-29-2013 at 09:19 PM. |
04-29-2013, 09:25 PM | #309 |
Thanks dlux, ill have to have a look see at the shafts. I don't have a build thread for my super. I really should start one. I just keep forgetting. |
04-30-2013, 07:12 AM | #310 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
I love all of this progress Erik! You've got alot of awesome going on with your super right now...Keep it up!
05-01-2013, 10:13 PM | #311 |
While waiting for my bearings, I took a look and wanted to get as little scrub out of the rear as possible. The hubs I was going to use were already pretty small, equivalent to a .100 SLW hub but I wanted more so I turned the hub down a bit, put a new pin hole in the hub and cut the end of the shaft down. I ended up with a .000 equivlent hub. I did some simple math and I believe I have .450" worth of scrub, not too bad, I am not sure how you would get less? .100 equivalent on bottom, .000 equivalent on top. |
05-01-2013, 10:16 PM | #312 |
I got my bearings and the car is complete. Now I just need to take it for a spin and I will also get some completed pictures. I am excited to test the new setup! Here is an above shot. I used to have the front and rear axles the same length so you can see how much scrub I used to run by looking at the front and you can see how little there is in the rear. |
05-01-2013, 10:30 PM | #313 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
Damn youse Erik. Where the hell is the door, I gotta get out of the super section....... The new chassis is badass!! Love how aggressive the little bastard looks |
05-01-2013, 11:10 PM | #314 |
Damn I really want to rebuild my super now .... you sum bitch! !
05-02-2013, 10:10 AM | #315 |
Very nicely done Erik! What's the weight now?
05-02-2013, 10:30 AM | #316 |
Holy Mackerel! I think I give up on Super...I can't keep up with all the cool shit you guys are doing... |
05-02-2013, 10:48 AM | #317 | ||
Thanks! If my memory serves, I think it was 5lb 5.5oz. Thats with no added weight and beadlocks. I weighed my bead locks and if I went to glue on, I could save 1.2oz per wheel or 4.8oz total. Meeehh.... I dont know that I care right now. I think I will keep the beadlocks. Give up? Nah, its just your turn to raise the bar. Tag, youre it! | ||
05-02-2013, 11:08 AM | #318 |
I'd still like to see a picture of it from the side now that it's put together...
05-02-2013, 11:11 AM | #319 |
No problem. I will get some shots when I take it out driving. I am just glad its done. Having to build these new axles for everybody and build a super is pretty taxing. Now I just hope to get a day here and there to drive my cars and enjoy them. |
05-03-2013, 01:37 PM | #320 |
Quarry Creeper Join Date: Feb 2011 Location: Germany
Rig and your steering angle look awesome Mr. D_lux
