Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Parallel wiring/EVX2/Single 7.2v stickpack?
Old 06-01-2012, 01:51 PM   #1
Default Parallel wiring/EVX2/Single 7.2v stickpack?
as the title says...
i have the EVX2 with the one battery connector bridged to allow me to run a single 7.2v stickpack on my clod.
as it stands it is wired as it should be with one set to the front and another to the rear from the ESC to the motors.
or can it be done? would it destroy the EVX2?
thanks
Torredo is offline   Reply With Quote
Old 06-01-2012, 05:56 PM   #2
Default Re: Parallel wiring/EVX2/Single 7.2v stickpack?
Why not run the motors as stock wired?
calcagno45 is offline   Reply With Quote
Old 06-02-2012, 01:05 AM   #3
if i am correct....the stock setup would be series meaning longer runtimes. i want more juicey-juice!
but can it be done or am i goin about this wrong?
another question:
im in the middle of a DIG setup using the Traxxas micro servo which is installed on a platform above my skidplate.
I have the stock Clodbuster "Power switch" that used to be installed on the side of the plastic chassis. Can this swithc handle the amperage from a motor in the 50-60+ turn range?
Parallel wiring/EVX2/Single 7.2v stickpack? - Similar Threads
EVX2 wiring?? SwampDawg Tamiya Clod Buster 11 11-08-2010 07:37 AM
Battery parallel wiring question pdm Electronics 1 01-09-2009 01:30 PM
wiring lipo's in parallel? fantomas Electronics 1 01-11-2007 07:29 PM
parallel wiring Question Over-Rev Tamiya Clod Buster 3 11-16-2005 03:04 PM
Parallel Wiring Crawly Electronics 13 07-14-2005 12:22 AM
