12-05-2008, 08:01 PM | #61 |
I wanna be Dave Join Date: Sep 2004
ive been using stampede shafts with metal yokes with no problems.
12-05-2008, 08:21 PM | #62 |
Quarry Creeper Join Date: Aug 2008 Location: UK
I received my HR shafts yesterday, and so far they have proved very good.
12-07-2008, 10:32 AM | #63 |
| Serious Problem!!!
I spoke too soon about the HR driveshafts. I discovered today that they have a really major design flaw. The pins in the universal joints work out, and after 10 minutes one of mine had fallen out completely! Fortunately, I was watching for it, and as soon as I noticed the front wheels lose power, I stopped and looked for the pin, and it was directly beneath the vehicle. I'm guessing that this doesn't normally present a problem when these sort of shafts are used on forwards only vehicles, because the constant forwards drive direction holds them in place. But on a crawler going back and forth and juddering over rocks, they can work out much more easily. Or have I just got a pair of bad ones? The driveshafts themselves are great, and I really want to keep using them because they are the best functioning so far. But this is a really serious problem that stops me being about to use them, until I can work out a solution. So, ideas guys? I'm really stumped the best way to contain the pins. |
12-07-2008, 10:52 AM | #64 | |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
12-07-2008, 01:25 PM | #65 | |
I might also file a small flat section on the pin for the screw to settle onto, so make it less likely that it will work free. I'm also considering a sleeve of some sort, as you suggested. The problem is that because its on the universal joint itself, sleeving it will limit its movement. I will have to use plastic or something to make something. Just seems so weird that they weren't tight already. I also kinda think that they could perhaps supply the allen key, since the screws are so small. | |
12-07-2008, 04:07 PM | #66 | |
12-07-2008, 11:46 PM | #67 | |
As for the size , you sure it's not a 1.5mm , 1.27 is pretty small and rare, 1.5 seem to be the most common, I have the topcads and they use 1.5mm sets. | |
12-09-2008, 06:53 PM | #68 | |
Oh, and having removed the shafts, I've now discovered that the loose pin carved a big juicy gash in the side of my Goat motor! Fortunately its in the metal band that I can replace, but still, this is a really nutty design flaw with these shafts, and very disappointing considering how well the rest of the shaft seems to be put together, and how well they could perform if only they solved the pin problem | |
