Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: ROCKEDUP RICKY's 1.9 COMP
Old 12-22-2008, 04:28 PM   #1
Old guy
ROCKEDUP RICKY's Avatar
Default ROCKEDUP RICKY's 1.9 COMP
I have been working on a 1.9 comp rig. Hopefully OKRCRC or NWARC will have a 1.9 class. We plan on having a 1.9 class at Crawlapalooza 09.
I started off narrowing the axles. I going with the RCP gears and CVCs in the front. I used a short axle on each side.
Here they are ready to go. I had these link mounts off my 1st TLT build. Had to mod them a little but they'll work. Makes them look beefy.
ROCKEDUP RICKY is offline   Reply With Quote
Old 12-22-2008, 04:37 PM   #2
Old guy
I'm using TCS clocked Cs on the front , so I made this servo mount .
I made the mount so the servo sits flat after the axle being clocked. Helps to keep the linkage up where it should be. With this mount my linkage sits higher on the face of the punkin, so the linkage will go farther back. It's just a little , but with no dig class you need every little bit you can find.
Old 12-22-2008, 04:42 PM   #3
Old guy
I always put rollers on my rigs, every little bit helps.
All on and feeling smooth.
Old 12-22-2008, 04:47 PM   #4
Old guy
Here's my shot at a chassis. Guys all I have is a steady hand and a dremel tool. Don't make fun. It will change when I get the AKRCC chassis gets done.
Old 12-22-2008, 04:49 PM   #5
Old guy
The electronis just fit in this thing. Not a lot of room on a 1.9.
Old 12-22-2008, 04:54 PM   #6
Old guy
I bought this body along time ago by mistake online. Pushed the wrong button. It's been sitting there for ever. It findly found a home .
I left the body a little high, I want to make some 4 inch tall tires ,but not sure what I'm going to make yet.
Old 12-22-2008, 04:57 PM   #7
Old guy
I'll do a little shake down and try to get some action shots or video real soon.
Old 12-22-2008, 06:06 PM   #8
Location: Taylors Falls just hanging with the MNRCRC crew.
Looks like a good rig Ricky like your axles mods.
Stormin2u is offline   Reply With Quote
Old 12-22-2008, 08:08 PM   #9
I wonder if you could flip the rear axle to get the pinion/driveshaft straighter with the trans output...the link mounts you have would make it pretty easy to do, from the look of it. Was thinking it might free up the rear end a little bit and keep things from binding with the angles you have going there.
DeaDShorT is offline   Reply With Quote
Old 12-22-2008, 08:10 PM   #10
Colt Python/SR9c
TwistedCreations's Avatar
Looks good Rick.. I cut and narrowed some 2.2 Rock claws and they measure 4". I'll probably try another set or tire, as I'm not too keen on the tread design
TwistedCreations is offline   Reply With Quote
Old 12-23-2008, 05:56 AM   #11
Old guy
Good idea,but then my rig would go forward and backward at the same time , it looks bad but it doesn't bind . I'm thinking I might narrow an axle the other way to bring it straighter. Then I would have to cut,drill and pin the axle to the gear. The way I did this one ,you don't have to do that,just use 2 short axles
Old 12-23-2008, 06:00 AM   #12
Old guy
I didn't care for it either, takes away from the tire. I like Sven's panthers. I've been cutting up all my old tires trying to come up with some thing. Anybody know how soft the rc4wd mud trashers are. they're 3.9 tall I think.
Old 12-23-2008, 06:43 AM   #13
Originally Posted by ROCKEDUP RICKY View Post
I didn't care for it either, takes away from the tire. I like EeePee's panthers. I've been cutting up all my old tires trying to come up with some thing. Anybody know how soft the rc4wd mud trashers are. they're 3.9 tall I think.
Soft. As for rock test. I will not know till Jan 4th.
I like the looks of the rig. Body is way cool. Nice choice.
Racer4Life is offline   Reply With Quote
Old 12-23-2008, 06:46 AM   #14
Old guy
why ,is 4th when you get out of jail or something
Old 12-23-2008, 08:41 AM   #15
How did you hear about it. Big Bubba told me to tell you have have pretty hands!
Old 12-23-2008, 09:37 AM   #16
Old guy
I sold you to Big bubba for a pack of smokes, He likes pretty mouth before he likes pretty hands.
Old 12-23-2008, 10:08 AM   #17
ROFLMAO!!
Old 12-23-2008, 10:29 AM   #18
lol!!!
what the width and wb?
dznutz is offline   Reply With Quote
Old 12-23-2008, 12:22 PM   #19
Old guy
Originally Posted by dznutz View Post
lol!!!
Width is 7 3/4 and the wheelbase is 8 1/2
I could take the width down to 6 3/4, I got some spacers in there now. But this is where I have it for now. I was heading out to give it a run, but it started raining. :-(
Old 12-23-2008, 10:52 PM   #20
Location: siloam springs, home of the Mid West Challenge 2010
Man you never cease to amaze me. I will have my MRC ready for the comp on the 24th
dustin keeler is offline   Reply With Quote
