12-05-2004, 03:10 PM | #61 |
Rock Crawler Join Date: Oct 2004 Location: The thumb
| Re: Mini Giants
here are the Traxxas tires I smoothed out and put dirt hawg treads on. I know they are far from perfect but I think they will work pretty well. Maybe the next ones will look better. |
12-05-2004, 04:35 PM | #62 |
I wanna be Dave Join Date: Jun 2004 Location: Centennial, CO
| Re: Mini Giants
Might be too late now. I was told a 24hour WD40 bath makes Jugg tires super soft, and they are supposed to be a hard tire as well. Just unload a can into a plastic baggy (sandwhich-ish size). But now that you glued the treads on, I don't know how it will affect them.
12-05-2004, 05:35 PM | #63 |
Quarry Creeper Join Date: Nov 2004 Location: Canada
| Re: Mini Giants
i have to admit those tires look bad ass! i need to look around the house at some of my old radio shack trucks and see if they got any good treads that will fit |
12-06-2004, 05:53 AM | #64 |
| Re: Mini Giants
actually they are pretty soft now I took the angle grinder with some 50 grit disks and ground some of the material as well as the nobs off and made a big difference. Now I'm stuck for another week cause I only bought a pair of dirt hawg and I don't have enough treads to do the other 2 tires... |
12-06-2004, 09:02 AM | #65 |
| Re: Mini Giants
go buy a bike tire with good treads and cut the treads from there |
12-06-2004, 10:39 AM | #66 |
| Re: Mini Giants
Y'know, if you post this over at one18th people are going to be crawling over themselves to get info on the tires and your chassis... |
12-06-2004, 04:39 PM | #67 |
| Re: Mini Giants
I've got a few pics of it up on one18th and Grafix the owner wanted to buy a bunch of chassis plates but I don't want to go into production with it. I'd like to try doing a better job on the tires but they are starting to get spendy so I only got one try. I've got to go to the HS again and get another pair of dirt hawgs so I can finish the other two tires. Oh and I got my gear reduction today so look out for a new chassis |
12-08-2004, 05:11 AM | #68 |
Quarry Creeper Join Date: Dec 2004 Location: Croydon, Surrey, UK
| Re: Mini Giants
Does anyone know if Losi Mini T wheels will fit on the VMG?
12-08-2004, 05:47 AM | #69 |
| Re: Mini Giants
Thats what is on mine :? here is my post It was actually pretty easy to mount those wheels on there... All I did was take the hex drive nuts off the MG and ground them down until they snuggly fit into the mini-t wheels where the bearing goes. I then CA'd the newly shaped drive nuts into the wheel and have had no problems with it. The wheels are all fronts. The tires are a stretch to fit onto the wheels but they work. I'm getting some bigger tires that will fit on those wheels soon and a gear reduction unit like Black magic has... ANd a new chassis. |
12-12-2004, 10:46 AM | #70 |
Pebble Pounder Join Date: Feb 2004 Location: Iowa
| Re: Mini Giants
Im thinking about trying to get my little brother a Mini Giant for Christmas just for rock crawling. From the looks of the vids. The stock tires are kinda crappy. How do they work stock on the rocks? Did u just glue the diff to lock it? Any simple upgrades for more flex? Thanks!
12-12-2004, 04:32 PM | #71 |
RCC Addict Join Date: Nov 2004 Location: Redding, CA
| Re: Mini Giants
stock tires work great with a couple little holes drilled in the rims. but thry lack in ground clearens.
12-12-2004, 05:55 PM | #72 |
| Re: Mini Giants
I just glued the front and rear diffs on mine...
12-12-2004, 09:50 PM | #73 |
| Re: Mini Giants
yea i just used good old CA glue to lock mine up!
12-12-2004, 09:58 PM | #74 |
| Re: Mini Giants
has anyone had problems with the wheel hexes striping out, i've gone through a couple now.
12-13-2004, 02:06 AM | #75 |
Rock Stacker Join Date: Apr 2004 Location: St. Louis, MO
| Re: Mini Giants
Just get Nylon locking 4mm nuts.
12-13-2004, 10:40 AM | #76 |
| Re: Mini Giants
Yeah, I switched to nylon nuts nearly right away.
12-13-2004, 11:00 AM | #77 |
| Re: Mini Giants
ya those strip easy to, but the torque from the gear reduction just strips out the little flat spot in the hexes
12-13-2004, 12:30 PM | #78 |
Adilynsdad too! Join Date: May 2004 Location: G ville
| Re: Mini Giants
Do any of you guys know where to get replacement hexes for the mini giants.
12-13-2004, 08:46 PM | #79 |
| Re: Mini Giants
i looked at the LHS today and they didnt have any so i might tri to order some.
12-14-2004, 05:58 AM | #80 |
| Re: Mini Giants
RC boyz one ebay have them listed. Its under steering rod set. they want 5.99 and 1.50 S&H. THE part # for the set is VEN-4409. I need to order some also my Gear reduction stripped mine out to.
