02-07-2007, 05:13 PM | #21 |
THAT THING IS SICK! I like the Oh $hit handles,nice touch.
02-07-2007, 05:16 PM | #22 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
nice job, cant wait to see this thing done
02-07-2007, 05:26 PM | #23 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
TOTALY SICK!! I just started on a Unlimited Baja Bug racer gonna be similar to yours, except 2wd. Just have the light bar drawn up and some sketches of roll cage and stuff.
02-07-2007, 05:34 PM | #24 |
wow, very nice tube work, never seen a bug tuber either, that is awesome! |
02-07-2007, 07:03 PM | #25 |
Built, not bought Join Date: Oct 2004 Location: Gresham
Very nice work.Keep it up.I won't pull the "do you want to marry?line".It's nice to see a woman that not only likes this sport but also,has some talent at building.Keep up the great work and keep us posted. |
02-07-2007, 07:15 PM | #26 |
Quarry Creeper Join Date: Jan 2006 Location: colchester
damn looks like you really did your homework on this one!!!!! its looking really good, cant wait to see how it turns out.
02-07-2007, 07:25 PM | #27 |
RCC Addict Join Date: Apr 2004 Location: Santa Clara
I am not much of a bug body fan, but the mix of the bug panels and the way you did your tubes, I must say VERY NICE JOB!!. I would love to own that rig. If you keep up the great work to the finish, it will definitely go down on my list of favorite all time crawlers. -Sam P.S. - sweet axle C-s |
02-07-2007, 08:02 PM | #28 |
Newbie Join Date: Jan 2007 Location: tacoma
you got sum skillz girl keep up the good work |
02-07-2007, 11:05 PM | #29 |
Newbie Join Date: Nov 2005 Location: Sun Valley, Nevada
Very nice!! WOW I am very impressed!
02-08-2007, 09:52 AM | #30 |
That is lookin good! Im gonna keep my eye on this build, im sure it will turn out killer. You might need a bit more tubework under the hood. One good nose-in will bend that front hoop. |
02-08-2007, 10:33 AM | #31 | |
I wanna be Dave Join Date: Sep 2005 Location: *
02-08-2007, 11:42 AM | #32 |
Quarry Creeper Join Date: Jan 2007 Location: Cuyahoga Falls
One step ahead of you, Last night I started fabbin up the braces for the front end, plus shock towers, I should have them welded in tonight. I was playin around with a trans mount last night but didnt care for how it turned out so i cut it off and started on a different bracket. got the uppers for the 4 link welded in and just need cleaned up a bit. I also ordered a set of white losi springs too. Radio and Hitec high torque servo should be ariving today. xoxo Natalie Last edited by NatalieMorgan; 02-08-2007 at 11:46 AM. |
02-08-2007, 12:07 PM | #33 |
Quarry Creeper Join Date: Nov 2005 Location: Pueblo West
damn nat , you are really kickin azz with this build , i kinda liked it before , but my eyes really opened up when i saw the hood and door skins on the chassis , that is too much for words , you definatly get a 10 for origionality and style points |
02-09-2007, 12:30 AM | #34 |
| Gettin closer...
So I just about finished with the front end when my Oxy regulator on my torches came apart... Arrrr... So this is as far as i got. Oh i did get the trans mounted, kinda overkill i think but better than not enough... I still have to hang the suspension, the shocks are going to clear nicely in the front but i am not sure where to set the ride height when i set it up. should the shocks be somewhat compressed or at full stroke? I keep hearin about 3" of GC but the steering servo is close to my front frame crossbrace. I hope I dont have to cut it off, I like how it looks, but function over fashion right? Im not sure if i mentioned before but this is my first build... itsdefinately a lot more challenging and involved than i would have guessed, but so far the result has been well worth he effort! I got my radio today, its a futaba 3pm, well see how it performs! thats it for now. xoxo Natalie Last edited by NatalieMorgan; 02-09-2007 at 01:09 AM. |
02-09-2007, 01:06 AM | #35 |
That looks great! Your going to have one bombproof bug! How do you want the suspension to act? Do you want all crawl or ability to speed up a bit too? If you want a full on crawl suspension I would suggest setting the shocks to be almost fully compressed at ride height (full droop setup). You can set it a bit lower and use fuel tubing on the shock shaft to increase the RH. Small springs are used internally to keep the shock compressed. Droop susp can take a lot of work to get dialed in. A high anti-squat will show up fast, and the vehicle will raise under power. Too little anti-squat and the susp wont want to let out and droop when the tires unload. A bit better handling all around would be setting the the shocks up around mid stroke. Some compression, some extension, whatever you need. Springs on the outside keep the shock extended. Last edited by JohnRobHolmes; 02-09-2007 at 01:09 AM. |
02-09-2007, 08:25 AM | #36 |
Rock Crawler Join Date: Jan 2006 Location: Colorado Springs
Hey Nat, Good looking rig! I'm from Slidell, its nice to see another down south crawler!! Just a quick question, where you gonna wheel that thing in the Big Easy?? You gonna drive out to Picayune or Pearl River? Keep up the good work, can't wait to see more! Tom |
02-09-2007, 09:34 AM | #37 |
Quarry Creeper Join Date: Aug 2006 Location: On A Big Pile Of Rocks
Can we all say dam good job, I had a real one that look like that 20 years ago, when you get it done post up again I cant wait to see it painted. Great job. Chimney |
02-09-2007, 09:44 AM | #38 |
Since your servo is so close to the front section on the chassis,you might wanna look into the droop set up.
02-09-2007, 09:56 AM | #39 |
Rock Crawler Join Date: Sep 2005 Location: IDK
That is some realy fine Tube work Realy ike De VW turned in a Tuber I would say 2,5'' CG is enough 3'' can be better but you'll have to share all the weight and bring al the weight as low as possible Keep up the good work!!!! |
02-09-2007, 05:03 PM | #40 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
lookin better and better
