Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Txt-1 and Juggernaut
Thread: 1:4 gear ratio Jugg axle
Old 01-29-2006, 02:02 PM   #1
Talking 1:4 gear ratio Jugg axle
i use a 12t pinion and a 40t gear modul1
changes the gear ratio from 1:2 to 1:4 and saves some weight , about 65g
hope it works
EGRESSor is offline   Reply With Quote
Old 01-29-2006, 08:15 PM   #2
CSR
That's cool!
I've read about folks running Stampede trannies with TXT axles needing lower gearing...... this could be the hot set-up for them. ;)
CSR is offline   Reply With Quote
Old 01-29-2006, 11:22 PM   #3
Nice! Lemme know if it works, I may borrow it...
-WRM
WRMorrison is offline   Reply With Quote
Old 02-01-2006, 11:50 AM   #4
Where can this 40t gear module be purchased?
Also, if your gear configuration is as you typed, a 12t pinion and a 40t module would only result in a 3.3:1 gear ratio.
40/12 = 3.33 ~ 3.3:1
BARK is offline   Reply With Quote
Old 02-01-2006, 12:12 PM   #5
dont forget the 15t and the 18t bevel gears
3.333*1.2 should be 3.99999999999 or 4
Old 02-01-2006, 03:17 PM   #6
MODERATOR™
EeePee's Avatar
Yeah, where?
Old 02-01-2006, 03:58 PM   #7
I want!!!
mike is offline   Reply With Quote
Old 02-01-2006, 07:10 PM   #8
Thats pretty sweet..! Let us know what your gonna do about it.. I am interested..
skipstr71 is offline   Reply With Quote
Old 02-01-2006, 09:51 PM   #9
Very cool deal! Makes me wonder why Tamiya didn't go with steeper gearing in the axles to begin with.... Anyhow, the 40tooth gear looks to be some sort of plastic. If so, are you concerned about durability? Please keep us posted!
fullmodtxt is offline   Reply With Quote
Old 02-02-2006, 07:00 AM   #10
Dirt Addict
roktoy's Avatar
Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Nice mod.....yes, let us know how it works.
Jay
roktoy is offline   Reply With Quote
Old 02-21-2006, 01:02 PM   #11
chassis in building
aluminium tube 10x1mm
dyna blaster tranny
i think i can test the axles within the next few days
Old 03-01-2006, 03:49 AM   #12
next step
must run within the next 2 days
Old 03-01-2006, 05:19 PM   #13
A parts list for the gear change would be great.
nice aluminium cage.
flatfender is offline   Reply With Quote
Old 03-02-2006, 06:43 AM   #14
Big Bear's Avatar
Location: Destination Hobbies, Ut Where The Fun Begins...
What he said.
Big Bear is offline   Reply With Quote
Old 03-02-2006, 08:32 AM   #15
varcor.org
swell searcher's Avatar
x3... feels like xmas waiting to open gifts...
swell searcher is offline   Reply With Quote
Old 03-03-2006, 11:34 PM   #16
v33
i guess EGRESSor gone OT with the gears thread and shifted to his tuber. can we please get back to topic? tia!
v33 is offline   Reply With Quote
Old 03-04-2006, 07:28 AM   #17
v33, it needs a chassis to test the axles
i am the next 2 weeks on Lanzarote and will let you know if it works like i think
its a nice little thing
Old 03-04-2006, 07:39 AM   #18
Did you know I HATE you? That's exactly the kind of clean rockbuggy I was dreaming of! Now, would you be so kind to sent it here just ASAP ?
J/K, ok I really like it, clean no-nonsense design.
Have fun with it at Lanzarote, and remember we will be in trepidating waiting for the gears mod!
rockspider is offline   Reply With Quote
Old 03-04-2006, 07:32 PM   #19
Big Bear's Avatar
Ok , pretty please can we have some part #'s on the 4:1 gears ? We don't care if they have been tested or not. Better to get sevral rigs out there testing them I say.
Old 03-20-2006, 12:22 PM   #20
after 20 hours
no wear on the gears
smooth low noise running and a minimum of torque twisting
dont know where you can get the parts in the US
a modul 1 12T pinion for 5mm shaft
and a modul 1 40T spur gear
some action pics
http://www.tamiyaclub.com/showroom_m...=45816&id=2511
http://www.tamiyaclub.com/showroom_m...=45823&id=2511
http://www.tamiyaclub.com/showroom_m...=45825&id=2511
HTML code is Off
