10-13-2006, 01:43 PM | #1 |
Rock Stacker Join Date: Oct 2006 Location: El Dorado
| Just starting
I did it! I just baught a TXT-1 and cant wait to get started. But there is soooo much info on this forum that I cant tell where to start. This is the setup I bought Tower Hobbies 2TXP 2-Channel AM/1 TS-53 Servo 70 75590 Tower Hobbies TS-70MG S2K Super-Torque 2BB Servo U Tower Hobbies 6-Cell 7.2V 1500mAh Stick Standard NiCd Tower Hobbies 420 AC/DC 6-7 Cell Charger Tamiya TXT-1 Monster Truck 4WD Kit Any comments or advice from you vets would be greatly appreciated. Also, anyone from the Tucson AZ area? |
10-13-2006, 02:02 PM | #2 |
| Oh yeah
Im not a machinist by any means and the only real machining tools I have are a dremel and a drill but I would like to do most of the fabrication and design myself. If someone could give me a good starting list of stock materials (alum. sheets, rods ect.) that would be great. thanks, mike
10-13-2006, 02:30 PM | #3 |
Rock Crawler Join Date: Jan 2005 Location: Nanakuli
there is a whole lot of other parts you are going to need just search this forum. but it looks like you also forgot the esc |
10-13-2006, 02:42 PM | #4 |
Anyone recommend a good esc? budget is limited right now, so most of the stuff will have to wait, I want to do more wrenching than running and slowly get all the parts. thanks, mike |
10-13-2006, 05:15 PM | #5 |
Quarry Creeper Join Date: Jun 2005 Location: Flagstaff
For a good starting starting point you should go http://www.rccrawler.com/20txt.htm As for the ESC your best bet is to do some searches to see what others are using. I use super roosters on my rigs. But they are hard to find now. There are all tipes of other mods you can do like this: Dig For TXT/Jugg How to. The key to a good crawler is to have a light chasse with the weight as low as you can get it. |
10-13-2006, 05:44 PM | #6 |
Newbie Join Date: Sep 2006 Location: Down underrrr
Get a tekin rebel 2
10-13-2006, 06:58 PM | #7 |
will a esc for a brushless work? do i need two, one for each motor?
10-13-2006, 07:18 PM | #8 |
Most people only run one motor. I run one 55t with a GD600.
10-13-2006, 07:25 PM | #9 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
Don what tranny you running? pinion and spur?
10-13-2006, 07:31 PM | #10 |
TXT trans 22tooth on motor and a 12tooth on the GD600.
10-13-2006, 07:32 PM | #11 |
so one lathe 55t and a esc for brushless will work?
10-13-2006, 07:33 PM | #12 |
You can use the mamba maxx esc, or the new tekin esc. They will control both brushed and brushless motors.
10-13-2006, 07:34 PM | #13 |
I don't think the brushless will work with a 55t. I think if I wore you I would try the tekin rebel 2.
10-13-2006, 07:38 PM | #14 |
Im testing the mamba maxx with an integy 55 now and I gotta say I LIKE IT! it is also 50.00 to 60.00 less than the other LRP or TEKIN esc's that run both |
10-13-2006, 07:39 PM | #15 |
you will wont a GD600 if you are going to run one motor. And you will have to play with the gear raito to get it to run the way you wont it. But as I said you should do some searching and ask a few other people. Its always good to get as much input as you can. |
10-13-2006, 07:42 PM | #16 |
im thinkin about getting a integy matrix pro lathe 45t, and a GD-600 ... shuld I go with the 15t, 12t, or 9t pinion? Are there any decent esc's for about 50$, I cant afford the tekin...yet? |
10-13-2006, 08:02 PM | #17 |
As for the gearing it's all in what works for you. And I don't know of a good ESC for around $50.00. |
10-14-2006, 03:11 AM | #18 |
Okay, Ive' been looking for ....9 hours now and cant seem to find an answer. The kit i bought comes with a 1500mAh NiCd and charger, what are the advantages of say a 3000mAh NiMh, bacause if I go to NiMh I would have to get a new charger as well. Also, waht is the proper maintenance for a NiCd? (fully discharge before charging...etc) Thank you all for the help, Mike |
10-14-2006, 03:43 AM | #19 |
You can run the MOPED 1/10 ESC from RCMART or off E-bay. It cost $35 bucks. I'm running it and had no problems from it. So are many others...It's a great ESC for a Budget.
10-14-2006, 08:22 AM | #20 | |
the higher the MAH the longer the run times ou may or maynot need a new charger see if it is capable of charging the nimh's nicads discharge 100% after each use | |
