01-17-2007, 06:16 PM | #21 |
That is what I was thinking as well, but you never know...there are some creative folks out there!
01-17-2007, 06:18 PM | #22 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
01-18-2007, 07:20 AM | #23 | |
01-18-2007, 12:43 PM | #24 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
Im not sure if they would fit with maxx yokes or not. I believe the ratio of the trans is 2.72:1, the spur/pinion (87/12) ratio is 7.25:1, and the axles are 2:1. After doing the math i get 39:1 gearing, which is super high. A tlt is geared lower than that and they have alot smaller tires. Doubling that to 80:1 would be enough gearing IMO. Thats why i wish someone had a 4:1 axle gear kit available. The rc4wd portal boxes look like a sweet solution but at $200 and a higher COG i would rather do something else. What about a rc4wd planetary reduction unit bolted to the motor? They are 4:1 that way you have room to gear up to get the desired wheelspeed, but you will need to cut the chassis to fit in the unit, or go to a shorter brushless motor. I just ran the numbers on my setup and its 56:1 and shorter tires, and i need alot more gear to be happy with it.
01-18-2007, 02:14 PM | #25 |
You know, I was thinking that would be a good solution, but was also unsure if it would fit with the SW2 chassis. With the wider skid, the motor is just inside the SW2 chassis. I think I might give that a shot as I dont think those larger spur gears will fit on the pede tranny with the Maxx yokes. Thanks for the tips! |
01-22-2007, 06:05 PM | #26 |
Well, a GRU a new Tekin2 and a 65T Axiom has my rig crawling as slow as could be! I think that 4:1 gearbox did the trick! BTW, I had absolutely no problems getting the GRU to fit in the SW2 with the 3" trans skid. |
01-22-2007, 07:50 PM | #27 |
NICE! I wish i could get parts up here that quick I ordered a 75t lathe as a cheap/easy solution to the gearing dilemma but it will be another 2 weeks until it even shows up There is no way i could get the GRU in my truck unless i hack a LARGE piece out of the chassis, because im running a R2 that sticks out of the trans cutout in the frame. Its cool that you found a fairly easy solution to the gearing problem!
01-22-2007, 07:57 PM | #28 |
Thanks for the compliment! Maybe you can clock that R2 90* and get a GRU to fit? |
01-23-2007, 08:54 AM | #29 |
Im actually thinking of reworking my entire drivetrain layout, which would reduce the torque twist tremendously, and move the battery weight around better. i would also be able to get a GRU in there no problem!
01-23-2007, 09:07 AM | #30 | |
02-25-2007, 10:37 AM | #31 |
03-01-2007, 08:22 PM | #32 |
Quarry Creeper Join Date: Mar 2006 Location: Terrell, NC
Nice and clean build now go get some rock rash on it |
03-01-2007, 08:25 PM | #33 |
Yeah, have been fine tuning some stuff and then ran into a few problems. After I wired up the rear steer and got it working, the front servo began to act funny. When I powered up the Tx and Rx, the front servo would turn completely to one direction and not move. Turn them off and I could move it back by hand. Now the ESC will not come on at all... Havent encountered this problem before on any of my other crawlers. BTW, I did not change the wiring setup of the front servo during rear steer install... |
03-15-2007, 06:20 AM | #34 | |
Rock Crawler Join Date: Jan 2006 Location: Colorado Springs
Check these two links out. EGRESSor has come up with that solution. I think he sells a kit, could be wrong about that though. 1:4 gear ratio Jugg axle http://www.photobox.co.uk/album/3252964 Tom | |
03-15-2007, 07:26 PM | #35 |
He doesnt sell a kit, but I did see that gear setup for sale on this forum.
03-19-2007, 05:50 PM | #36 |
Newbie Join Date: Mar 2007 Location: southamtion
cool i like the body
03-19-2007, 08:06 PM | #37 |
Thanks!
03-19-2007, 08:22 PM | #38 |
What servo are you running on the back? The front is a 5955 right? If the rear is a digital, you will need a rx pack or voltage regulator. Quite a few people have fried the BEC on the TR2 running 2 digital servos.
03-20-2007, 05:33 AM | #39 |
The rear has a 645. I do think that my ESC is fried though. The crawler worked fine and then one day, nothing. I cant get the esc to turn on.
03-25-2007, 09:04 PM | #40 |
Rock Stacker Join Date: Feb 2004 Location: Jerzey
any test runs yet? Alfy |
