Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: front suspension
Old 12-03-2012, 08:08 PM   #1
Default front suspension
hi all, i am wondering where (or if) i can buy the entire front suspension set up? i have looked every where and can only find bits and pieces. and if you cant get all the pieces together can you name the individual part trees i need to get?
i have the chassis already i am just after the front suspension. and i do know of the rc channel ones (A. CC-01 front and rear Metal axle kit, Rc Channel - The Worlds of Rc Car Parts) but there a bit out of my price range i just want the stock plastic ones.
cheers!
dcrou7 is offline   Reply With Quote
Old 12-03-2012, 11:14 PM   #2
Default Re: front suspension
GPM manufacture all the front suspension components. See if they are cheaper for you here, Tamiya CC01 Parts, Aluminum Upgrades, Bearings | AsiaTees.com
As for OEM plastic parts, get ready to buy a lot of stuff. Going off this manual, http://www.tamiya.com/english/rc/rcmanual/cc01.pdf, you need the following:-
B parts bag
C plastic tree
D plastic tree
B plastic tree needed for the steering linkage and C-hubs
W plastic tree for the front knuckles
You will at least need the B parts bag with either option for the relevant screws, etc.
derb is offline   Reply With Quote
Old 12-04-2012, 08:23 AM   #3
Ask in the wanted section. I just ordered most of the aluminum front parts from asiatees. Might be able to help you out when I get mine in. Should be next week.
msmith0322 is offline   Reply With Quote
Old 12-05-2012, 01:21 AM   #4
thanks for the replys guys, much apreciated. i will be looking into the gpm alloy parts more affordable than the rc channel ones.
front suspension - Similar Threads
independent front suspension and front diff build canadian scx10 Axial SCX-10 1 02-13-2011 07:52 PM
Lifting CC-01 front suspension bb6cc01 Tamiya XC/CC01 7 09-14-2009 06:42 PM
Widening the front suspension.... toyofast Tamiya XC/CC01 23 07-10-2009 09:29 PM
in board front suspension Bknight General Crawlers 4 02-07-2006 06:13 PM
