Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: 1.9 Scaler Tamiya Style
Old 01-19-2013, 01:10 AM   #21
Default Re: 1.9 Scaler Tamiya Style
Originally Posted by JatoTheRipper View Post
Sweet ride! Very nice work!
The CC-01 kits are so tempting because of the scale potential.
Sent from my Amazon Kindle Fire using Tapatalk 2
That's what made me pick one up
Abavuso is offline   Reply With Quote
Old 01-19-2013, 01:17 AM   #22
Alright, I finished sculpting the body. I don't know why I didn't think of modding it prior to painting it. Perhaps I just got carried away. Any how, I cut the front bumper on each side at about a 45 degree angle and then caped them off with some .80 styrene so that it has a finished look. then I had to widen the wheel wells a little bit. I did my best to make them blend so that once the finishing sanding is done and the paint reapplied you shouldn't be able to tell I hacked it up just a touch. Hear you are, I can now drive it without those big tires rubbing
Old 01-19-2013, 04:08 AM   #23
Ah! Now I know what to do to make the tires fit in the wheel wells!
the-gamer is offline   Reply With Quote
Old 01-19-2013, 08:34 AM   #24
There's ever so slight of a rubbing on the tub chassis still but that's livable for now. Next on to the interrior! But first, I've got to take her out and play.
sent using taptalk 2 - This is not the Droid you are looking for.
Old 01-19-2013, 03:17 PM   #25
I know what you mean about the rubbing! I had a set of 1.9 Pro-Line TSL's on my first CC01 and they rubbed a lot! But it was a lot of fun!!
Old 01-19-2013, 06:02 PM   #26
Man that thing looks tough!
The DC is offline   Reply With Quote
Old 01-20-2013, 03:59 PM   #27
Thanks
I need to get the GPM steering upgrade, there's way too much slop in the steering.
Old 01-21-2013, 01:06 PM   #28
So my next quick mod is going to be adding a full size spare to the back of the truck. I found spare tire mount on flee bay. I'm going to get that and then I found a single proline wheel to mount he spare on. Now I just have to find a single flat iron so I don't have to buy a pack of them.
I did take her out in my yard for a little bit and crawled on some junk lumber in my yard, she handles very well in my opinion. I'm thinking I need to upgrade the electronics and swap in my BRXL, and BEC for the servo so I can up the voltage. The NIMH packs last a long time, they just lack the umph I need.
Next mod, --- mid that motor plate to take a smaller pinion, I'm thinking two more mounting holes, 12t and 14t pinions should do the trick... perhaps even a 10t pinion and I'll be golden. but we shall see.
Here's some action shots from today's little drive... I can't take her on too much difficult terrain yet because the 55T motor got wicked hot in 45min of driving on gravel, grass and planks.
Old 01-21-2013, 03:18 PM   #29
That looks awesome mate! I love the tyre squish in the second last pic. People say Flat Irons are too big for scale, but I reckon they are perfect. Look just like 35" tyres I think.
derb is offline   Reply With Quote
Old 01-21-2013, 03:33 PM   #30
I thought that too but after I opened up the fenders a touch, they look like they belong.
Old 01-21-2013, 06:41 PM   #31
If you take a 3mm drill bit and put a hole just over half way between the 16 and 20 hole, you can drop in a 12t pinion... makes a huge difference in power with little speed loss. you have to use two counter sunk screws for it to work. The gear cover is a little tight going back on, but it it fits!!!!!
This photo has a cap screw but thats before i realized that the cap prevents the cover from going back on.
Old 01-26-2013, 04:19 PM   #32
Got her out on the trails and the rocks today!!!!! Totally fun!!!! Now I need to tune the rear suspension a touch and we should be strait! that and i need to finish my esc upgrade.
With me scx10 axled wraith cage.
Old 01-26-2013, 06:13 PM   #33
i like it!
2manyprojects is offline   Reply With Quote
Old 01-30-2013, 06:46 PM   #34
So I found this spare tire holder on e-bay. It's really nice and well built out of aluminum. It's a little heavier than I would like, but it works really well. Check it out.
Old 01-30-2013, 07:12 PM   #35
That's a nice bit of kit. Junfac make one for the Pajero too but it's much the same.
Old 02-03-2013, 09:06 PM   #36
hey can you post a level side shot of your rig? im trying to stuff some flat irons under my pajero as well and wanna see where the body ends up in relation to the tub.
Koldham is offline   Reply With Quote
Old 02-03-2013, 09:26 PM   #37
Here you go.
Old 02-06-2013, 08:09 AM   #38
hey thanks a bunch
Old 02-07-2013, 08:16 AM   #39
I've been thinking about the portal hub mod. Does anyone, know what the gmade r1 rear axle width and gear ratio is? If its not too wide then you could use that in the rear and the cr01 portal knuckles in the front.
Old 02-07-2013, 03:12 PM   #40
I've got info to drop on your this morning. I have both a CC01 and an R1 and have done a fair bit of research into the portal ideas. First things first, no idea on the gear ratio, but I can measure the hex to hex distance for you tonight. It is much wider than the stock axle, but will let you test yourself once I get the dimensions. Also to keep in mind is that the portal hubs for the front run a gear reduction unless you do the 1:1 mod as shown in this post, High Clearance CC-01 Power to the portal!, and the reverse the wheel direction sicne there are only 2 gears in there, not 3.
I think it's going to be quite hard to match all the ratios up, so my plan was to do the front hubs with that 1:1 mod and then flip the rear axle 180 degrees since the front portals will reverse the drive wheel direction. This way you can just reverse the motor channel on your transmitter to make it go forwards instead of backwards. Flipping the rear axle is easy and you side step any bad underdrive/overdrive combos, and you could make the Junfac 4-link work with just a little filing. Possibly the GPM 4-link kit, but I don't run that one so unsure on it. If you run some bigger shocks and nice, big 1.9 tyres you'll have plenty of clearance under the rear end.
Let me know if you want any more info and I'll see what I can dig up.
1.9 Scaler Tamiya Style - Similar Threads
TAMIYA CR-01 FJ-40 OEM style RIMS LRS30 Tires and Wheels 3 03-06-2011 12:25 PM
beadlock wheells to old style tamiya hubs kronos Newbie General 2 05-08-2008 10:42 PM
found tamiya style upper-lowers tsaun987 HPI Wheely King 2 05-24-2007 05:32 PM
