Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: Motor/gearing help.
Old 03-30-2015, 01:42 PM   #1
Default Motor/gearing help.
My current setup is 1.55 mtz's, 3s, 85t brushed, and the gpm spur with the the small pinion. Original gearing was 16/80. Speed was perfect. I had a spur issue and replaced with the gpm stuff. much stronger but now I think its too fast. I used the small pinion in the gpm kit so now its 13/6? dont know the spur count. On top of that I want to swap to a 1.55 mud thrasher which is taller than my mtz's. How do I gear down?
redneckracerx is offline   Reply With Quote
Old 03-30-2015, 06:11 PM   #2
Default Re: Motor/gearing help.
If you are already using the smaller of the two pinions the only thing I know of to do is install a Gear reduction unit.
Jeepiac is offline   Reply With Quote
Old 04-16-2015, 03:55 PM   #3
Sol unless you go to a reduction unit. Rc 4wd makes 2,3,4:1 bolt in planetary reductions
Reaxion911 is offline   Reply With Quote
Old 04-20-2015, 08:05 AM   #4
Wow, sorry to not get back to this sooner. What I was trying to say is which gear reduction do I go with to get back to my original setup?
Motor/gearing help. - Similar Threads
Motor/gearing? remington7 Team Losi Comp Crawler 4 12-09-2014 11:35 AM
Gearing or motor? 6sharky9 Newbie General 9 08-11-2013 07:05 PM
20t motor and 45t motor gearing question? rcstrike Newbie General 1 11-16-2011 03:40 PM
motor gearing grizz Electronics 2 02-26-2008 04:41 PM
Motor Gearing crawler nate 66 Electronics 0 01-28-2008 05:22 PM
