Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: need steering ideas
Old 05-09-2015, 02:38 PM   #1
Default need steering ideas
gpm kit is junk. need some ideas. like to get the bell cranks i think there called gone. ideas? thoughts?? pics would be great. thanks
m1009cucv is offline   Reply With Quote
Old 05-09-2015, 05:04 PM   #2
Default Re: need steering ideas
Hi: I have used the aftermarket cranks and find the problem is they never really tighten up to stop the slop. I replaced the steering arms with ball links and 4-40 rod. The modification that did it was to put just a dab of JB Weld on the bottom of the crank that goes through the body to the steering unit underneath or on the lower steering unit itself and put a dab of JB on long screw on bolt that connects the two and tighten them up. Make certain to grease the cylinder well. When everything sets it is rock solid. I have done this to three units and the steering is excellent.
HCCrawler is offline   Reply With Quote
Old 05-16-2015, 07:33 AM   #3
was thinking about getting rid of the crank steering
Old 05-16-2015, 11:48 AM   #4
I mounted a servo on a bracket across the ft fenders. ran a link to old buggy bellcrank mounted vertically on the "brick". I flipped the knuckles left to right so the steering link was on the front of the axles. Then ran tie rods from bellcrank to knuckles. With a little fine tuning I had much more steering angle than normal. I researched and found other setups like this and tried them but the bump steer when the suspension would compress made the setup useless. That's why i integrated the buggy bellcrank into the design. I had nearly no bumpsteer after a bit of tuning.
vinnyphx is offline   Reply With Quote
Old 05-17-2015, 10:19 AM   #5
Just a random thought but could you not invert the servo basically In the same position it is stock and stop using the GPM or stock parts. Kind of like a Traxxas Slash from memory? Just an Idea
Drakken is offline   Reply With Quote
Old 05-21-2015, 10:59 AM   #6
any pictures? was thinking about removing some plastic.. mount the servo on the fenders. long servo arm. all thread links right o the knuckle
Old 05-22-2015, 06:51 AM   #7
No pictures just a total random idea but look up a Traxxas Slash chassis photo which will show you what I mean
need steering ideas - Similar Threads
Idea for scaler steering... Need ideas for building a steering box. JavelinSST390 General Scale Talk 25 05-14-2015 02:32 PM
Steering servo ideas Skizurp Vaterra Twin Hammers 5 07-06-2013 12:51 PM
Steering question ideas. RickM Axial AX-10 Scorpion 1 04-14-2010 06:32 AM
Steering cutting out, ideas please... Ralphy Electronics 3 04-17-2009 01:36 PM
Need help with steering ideas Tim_B Chit Chat 3 04-03-2008 08:41 PM
