01-21-2016, 12:41 PM | #1 |
Newbie Join Date: Dec 2015 Location: UK
| Clacking gears with aftermarket motor.
Basically, it runs smooth as hell with the silvercan (and WAY too fast), but the RC4WD 65T motor I bought for it makes the gears "Clack" when it runs in either direction. The two motors have identical dimensions as far as I can tell except the motor shaft is a little longer on the RC4WD. Any ideas on how to get the gears to run smoothly with that motor? Any help is greatly appreciated |
01-23-2016, 02:07 PM | #2 |
| Re: Clacking gears with aftermarket motor.
I found when I switched pinion gears the set screw was contacting the spur gear. Making a small mark on the pinion. Check it out before you do damage.
01-24-2016, 11:08 AM | #3 |
Thanks I'll give it a look.
Clacking gears with aftermarket motor. - Similar Threads | ||||
First Time Drive Yeti - Clacking Noise | SilicaStorm | Axial Yeti | 19 | 10-19-2014 07:18 AM |
What aftermarket spur gears fit? | Beej | Axial Wraith | 14 | 12-13-2011 08:05 PM |
which motor...or gears | WICKEDWOLFRC | Newbie General | 7 | 07-07-2010 10:38 AM |
motor or gears | Bad Karma | Newbie General | 6 | 03-02-2010 08:11 PM |
