Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: Starting a second cc01... but a unimog this time!
Old 10-12-2015, 07:02 PM   #21
Default Re: Starting a second cc01... but a unimog this time!
Oh yeah, special mention for the rc4wd Krypton 1.9... Very smooth and sticky, soft and grippy...
noname0383 is offline   Reply With Quote
Old 10-12-2015, 07:04 PM   #22
time for a short video...
https://youtu.be/oQ3yE0VqhXk
Old 10-14-2015, 11:20 PM   #23
As you can see in the video, my rear suspension is quasi inexistant... way to hard...
So a friend of mine give me 2 scale shocks internal springs 70mm... They are soft and way better than the stocks i had... I only put 1-2 drop of oil to keep them lubricated and thats it... Problem solve...
Almost same flex but waaaaay smoother...
Old 10-14-2015, 11:28 PM   #24
The same friend also gave me the junfac skid plate... I have it on my other cc01, it really help protecting underneath and help to ''slide'' better (imo) over rocks but also lower the ground clearance...
So basically i ''open'' the 2 side of the skid and flatted the rear... This allowed the skid to be as close as possible to the chassis... Now i only have to dremel a bit the front of the skid to smooth it out...
Old 10-15-2015, 12:53 AM   #25
Somethings not quite right with the skid. I believe it's supposed to go under the steering/front control arm skid...so that it sits flush with everything...not at an angle. Plus, with the way you have it mounted it can get hung up on things.
slow1500 is offline   Reply With Quote
Old 10-15-2015, 01:01 AM   #26
Not according to Junfac website...
CC01 Chassis Skid Plate [J20022] : JunFac.com
Because of the trans under the chassis, i don't think you can fit the skid under the steering/front control arm skid... But still, maybe i can work something
Old 10-15-2015, 01:02 AM   #27
But as i said, i will dremel everything so the front skid will be flush and smooth ;)
Old 10-15-2015, 04:36 PM   #28
The older one I remember goes all the way to the diff, Might be the same slow1500 was thinking about, I like how you done this as well as I like the angle of it, would go nice with some bent lower links.
Absurd is offline   Reply With Quote
Old 10-15-2015, 06:38 PM   #29
Hummmmm, great idea here my friend...
Old 10-16-2015, 10:57 PM   #30
Did a little of work on the mog...
Grind the inside of the skid to fit the trans... I took off as many material as i can...
Smooth the front of the skid so everything fit nicely...
Old 10-16-2015, 11:01 PM   #31
and now you asked for it... Bent links
Old 10-16-2015, 11:04 PM   #32
And i add Junfac sliders... I fit them perfectly to the chassis for maximum protection and style
Old 10-17-2015, 06:14 AM   #33
I wish they made those in black. I mean I know I can paint them but I bet it would not stick well.
Habanero is offline   Reply With Quote
Old 11-11-2015, 06:43 PM   #34
today's ride...
Old 11-15-2015, 01:11 PM   #35
During my last ride, i found out a problem with my steering...
A screws at the bottom kind ofget loose so since i had to take the steering, skid etc apart, why no modified the skid a bit more...
Now i'm gonna put some sticky(?) weight on the skid... Those little rig runs better when trey're a bit heavy...
Old 12-15-2015, 10:09 AM   #36
Great build! Love the way your Mog works. Mind if I ask to learn/ see more about how you converted your 'box' to a flat bed? Considering building my CC01 as a Case MB4/94 which, to be accurate, needs to have a flat deck instead of a box.
-Evan
etmccaus is offline   Reply With Quote
Old 12-15-2015, 05:26 PM   #37
No prob... Will try to take some more shots of "under the cab"...
But basically, I took 2 pieces of hard plastic, held together with "L" metal pieces and used Shoegoo to glue the flatbed to the cab...
Not sure it's clear lol... Pics will be better... ;)
Envoyé de mon LG3 avec Tapatalk
Old 12-15-2015, 06:30 PM   #38
As u can see, i kept the lower part of the rear cab to hold the flatbed
The ''L'' metal pieces that hold the 2 parts of the flatbed (at the front of the flatbed)... everything is glued with Shoegoo...
And a bit of mods to the chassis to be able to fit the flatbed lower than normal...
If u have more questions or need precision, plz ask... will do my best to anwser clearly...
Old 12-15-2015, 08:41 PM   #39
Hate to be a bother, but I just signed up to ask. What were the steps you took to make the flatbed? I have a clear lexan mog right now and really wanted to do a flatbed. Was it as simple as cutting the top off and only leaving the small overhang for the tail lights?
I would love to know what you did to the chassis to accommodate.
Thanks!
Alecdvv is offline   Reply With Quote
Old 12-15-2015, 10:25 PM   #40
That's almost exactly how I did the bed of my Unimog a few years ago!..plexiglass and aluminum.
Starting a second cc01... but a unimog this time! - Similar Threads
First Video/Unimog CC01 DieselJC Scale Videos! 3 11-11-2012 01:40 PM
About to order CC01 Unimog.. help? kevin107 Tamiya XC/CC01 1 07-06-2011 02:47 PM
