Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Tamiya Scale Rock Crawlers > Tamiya XC/CC01
Thread: We bought a 'Zu
Old 01-14-2017, 09:38 AM   #1
Default We bought a 'Zu
Got hold of a Tamiya Izuzu Amigo body in a trade that was a little worse for wear. I figured since it was already beat, it would be a fine body to take out on the woods and trail worry free!
I was debating some sort of solid axle rig, but in the end it was right at home on a CC01 chassis. I had one here I was messing with converting over to an HPI suspension, and after some wheelbase adjustments, it dropped right on.
It had a 3:1 reduction and Tamiya Xacto mini motor ready to go - best combo out there for a trail ready CC chassis. I also used some lead fishing wire to line the chassis rails to add some weight down low.
Rear suspension is some modified Wraith brackets to angle the shocks for a bit more travel.
Front is the HPI converted IFS of course.
A look at the bottom. Junfac sliders and some others odds and ends
The body was missing the rear section, so I added some cross bars and mesh to fill it in. A modified Dingo interior is also velcro'd in.
The PO of this body used a lighter apparently to melt and flare out the wheel wells. They were (are) a wavy mess on all for corners...I started sanding down to get them close, and eventually I'll fill a bit so they are somewhat straight. The orange paint has to go, so there's a lot of bodywork in the future for this truck.
Painted the details on the grill and removed the front bumper as it was cracked and ugly. Now has a much more appropriate off road front end!
Been working on this in between my CR01 1.9 build...more to come!
OSRC is offline   Reply With Quote
Old 01-14-2017, 01:13 PM   #2
Default Re: We bought a 'Zu
Do you have pics of the dingo interior installed??
VR6 BeelzeDub is offline   Reply With Quote
Old 01-14-2017, 03:51 PM   #3
Ooooo. Nice.
Are those the MST tires? They look great. Perfect size for these CC-01 trucks.
How do they work?
JohnnyAnguish is offline   Reply With Quote
Old 01-15-2017, 06:47 PM   #4
So Jealous.
I own a 1:1 isuzu amigo, and I've been looking for one of the Mu bodies off and on for about 2 years. finding one in any condition is a good find, I like what you've done so far with tis one.
makya is offline   Reply With Quote
Old 01-16-2017, 05:49 PM   #5
Any more info about the HPi front end parts?
BigSki is offline   Reply With Quote
Old 01-17-2017, 06:30 AM   #6
Originally Posted by JohnnyAnguish View Post
Are those the MST tires? How do they work?
No idea yet. A friend runs them on his D90 and is very happy with them. We'll see...they seem a little hard.
I'll take a pic from underneath. It's just cut to fit and velcro'd in there. I did have to hack a hole for the steering servo to poke though.
A whole thread in fact sir : CC01 Front suspension swap
Old 02-25-2017, 05:03 PM   #7
Got a good 1/2 hour or so in on the 'Zu this morning. Tires did better than I thought they would, and they are not broken in at all yet. Front suspension worked like a champ...If I can cobble it together, I may convert my other one. Bodywork is waiting for spring...
Yes, it got up the face of that rock. I have no idea how. Sorry for the blurry pics.
Old 02-26-2017, 08:52 PM   #8
Good to see that Tamiya M-Special motor in there! I now have tracked down 3 more brand new units and I'm to 4 of these things total.
My CC-01 is however, still sitting in a box unbuilt as I've been preoccupied with getting an MF-01X to work as a mild trail rig. After putting on some drift tires, I decided that the little M-Chassis is better suited as a drifter or rally car than a trail rig. Now I can work on the CC-01...
K.O.M. is offline   Reply With Quote
Old 02-27-2017, 05:57 AM   #9
Those motors and the Xtra speed 3:1 reduction boxes are the best combo I've ever dropped into a CC chassis.
Old 02-28-2017, 01:38 PM   #10
I love that body. The modifications you made to the back look fantastic.
Old 03-01-2017, 12:35 PM   #11
edit: nm read thread about tires
tpliquid is offline   Reply With Quote
Old 03-12-2017, 08:38 AM   #12
I like the gear reduction and motor combo and not needing to cut into the battery tray. What are the dimensions on the motor?
Dirt Runner is offline   Reply With Quote
Old 03-12-2017, 09:43 AM   #13
The can itself is about 25mm long. The entire motor is just under 45mm.
Old 03-12-2017, 10:03 AM   #14
Thank you. I also meant to ask if it was bolt on for the gru or did you have to trim at all.
Thanks again,
Joe
Old 03-12-2017, 11:36 AM   #15
It's an Xtra speed 3:1 planetary GRU. Much better then RC4WD's....quieter, smoother, and seems stronger to boot. No problems assembling that I can remember. I think i had to trim off a bit of the battery box for the bearing seat on the motor, but it was very minimal.
Old 03-12-2017, 03:43 PM   #16
This just sold me on swapping out my HPI GRU unit. Amazon has it for under 20 bucks shipped!
Thanks for sharing this mod!
SFC K is offline   Reply With Quote
Old 03-22-2017, 01:20 PM   #17
Natedog's Avatar
Nice fixes for a sweet Tamiya Isuzu, always wanted one of these when they first came out in the 1990s was pretty cool in orange. Buddy had one with Toyota double transfer case setup. The Tamiya M motor and Xtra Speed GRU really work in the limited chassis space too. I keep resisting the temptation to buy one of these Tamiya kits because I have too many projects.
Old 03-22-2017, 02:02 PM   #18
Thanks Natedog, they are a ton of fun. I've had 10-12 of them over the years...have 5 currently in various forms and probably 2-3 more in parts laying around.
Reason they are fun is they are a challenge to mod and improve. Take a new SCX10 or Ascender - either one is a fantastic performer out of the box, and most mods made only improve it incrementally. A CC01 on the other hand starts as a terrible trail vehicle, so there are some night and day mods you can make along the way. It's very satisfying when your hard work really pays off.
Hope I'm explaining that correctly.
Old 03-25-2017, 12:23 PM   #19
I miss my old CC-01 'Jero. I had shortened scx-10 shocks, out-boarded rear mounts on home made axle mounts, locked diffs on both ends, a few front end mods and a GRU. it was the most fun little rig I ever owned.
Old 04-10-2017, 05:49 PM   #20
Now featuring an HPI front suspension and Ascender rear axle....
CC01 Underdrive mod.
Future updates specific to this truck will be here.
We bought a 'Zu - Similar Threads
Built not bought, with a bunch of things I bought. imthatguy Axial SCX-10 28 01-10-2016 08:41 PM
bought fx-r troy95chevy Electronics 13 08-23-2011 12:17 PM
just bought an AX-10 SSpeeDEMONSS Axial AX-10 Scorpion 27 02-10-2009 01:51 AM
Just Bought.. Andydrift 1.9 Scale Rigs 4 10-18-2008 05:01 AM
look what i just bought usa1man Chit Chat 2 03-01-2007 10:21 AM
