10-27-2009, 10:35 PM | #21 |
Pebble Pounder Join Date: Jul 2009 Location: veneta, oregon
you will like the alt, i have it on my rig and it is bad ass!!
10-27-2009, 10:36 PM | #22 |
Rock Crawler Join Date: Aug 2008 Location: Portland, Maine
| Post one up I want to see. I run a 3 cell Lipo in my Mini and it is way too much power. Check this http://www.youtube.com/watch?v=V7Yvz23gK5o |
10-31-2009, 09:44 PM | #23 |
| Update- While I'm anxiously awaiting for my DMG A.L.T tuber to arrive, I painted up the stock grappler pro body. I went with Green and Black because thats what I had for paint. The body fits good and Losi did an amazing job with the pre-drilled post holes. Funny how the little things make the difference. I put the stock wheels back on the crawler as the Vanquish Pro comps and Rovers will be getting special treatment from some new Nova's Ark dual stage foams. Very excited to try these foams, have read and heard lots of positive feedback. At this point all I have left to install - - DMG A.L.T tuber - Nova's Ark dual stage foams - RockSmith Engineering outboard shock kit...if it ever gets sent? - The finishing touches Can't wait for this stuff to all come together. Last edited by Wild Snapper; 10-31-2009 at 09:46 PM. |
11-01-2009, 05:59 PM | #24 |
So I got out today and did some great crawling. I'm starting to really like this Losi and get used to it as I'm coming from an AX-10. Again I got 30+ minutes of battery time on a standard 1300 3 cell lipo from ckrc. Just like before I wasn't able to hit the cutoff and run the full battery. This time it was because the slipper clutch came loose and I had to stop. I'll retighten tonight but I'm hoping this does not become a habit. I'm not very fond of slipper clutches, it takes away from the overall feel of a crawler when it's nearing it maximum stress point if I'm explaining that correctly. Anyways I'm lovin this crawler and can't wait to do a comp with it. Anyone have experiences or advice with the slipper clutch other than tightening it back up? Thanks |
11-01-2009, 08:30 PM | #25 |
Just got the heads up from Jerry at DMG that my A.L.T chassis is on it's way tomorrow. Candy gold to match the bullet weights in the Vanquish wheels. Can't wait. Sweet........... |
11-03-2009, 09:38 PM | #26 |
| Update... Today I installed some Nova's Ark dual stage foams for my HB Rovers. All I can say is WoW . These foams are it. The best I've ever used. Hands Down. Amazing. They can be purchased here for anyone wanting their Rover to come to life. Original Design (2009) - 2.2 and 1.9 dual stage foams And you can see them in action here HB's and Nova's dual foams video review. Anyways the install was a snap thanks to the Vanquish ProComps, but I wanted to put up some pictures for you guys to see the difference these foams make. I like pictures if you guys haven't figured this out yet. What I wanted in these foams, was for the Rovers to fill in and become narrower to give a little more room for turning, which the stock foams were incapable of doing. The Nova's are nice and soft close to the outside of the tire and stiff with great sidewall support closer to the rim. Many people on here say that the stock foams are great.............my guess is that they haven't tried these Nova's foams and don't know what their missing. These are not memory foam so temp in not an issue....winter is coming. Check out the first two pictures and see the difference between the Nova's and the stockers. The Nova's are on the left side. Enjoy |
11-04-2009, 02:58 AM | #27 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
Looking good!!.. |
11-04-2009, 04:03 AM | #28 |
Rock Stacker Join Date: Oct 2009 Location: Dane Country
Tremendous build thread! Photos add greatly to thread, also helps Newbies. Nice A.L.T. Chassis and color selection!! Thanks for sharing.
11-06-2009, 06:12 PM | #29 |
| Update... Today was a great day. I finally got my Rocksmith Engineering outboard shock kit and installed it. This kit moves the rear shocks out away from the body to improve stability and reduces role in the rear. This helps with steep climbs and minimizes the torque twist associated with any shafty. This system is not for the front shocks, only the rear. Check out the before and after picks. It is a great system and sells for $5 bucks...great deal if you don't want to go to the hardware store. The 2nd pic is the stock setup that Losi did for perspective of change. All the rest are the Rocksmith system installed. I definately suggest this simple upgrade...Enjoy |
11-06-2009, 07:30 PM | #30 |
| Update...a good one ! Well today was the day...Jerry from DMG sent me a beautiful candy gold A.L.T aluminum chassis. It mounted up perfect and literally weights less that the painted lexan top that was on the crawler before. All I can say is that this crawler is now officially dialed in and f*#%ing bad ass. Anyone that's been in the crawling scene for a while needs no introduction to DMG, but for those of you who are not, these are high quality frames with alot of attention put into them....Thanks Jerry this chassis rocks! I sent in some side panels made out of cut lexan to get painted with the chassis panels. When they arrived the first thing I did was cover the painted side panels with clear packaging tape and trimmed the edges. This way when the side panels rub against the metal Losi frame the paint won't scrape off. A little trick that is helpful in preserving paint. Not that this thing stands a chance, I'm going to rally this thing to hell and back. It will only be pretty for another day or so. At this point the crawler is just about done. All I have to do now is install an RCBros metal motor mount to harness this beast and some fine tuning of the suspension. I still need to move the ESC for a little more protection but this frame will do what I needs it to, very minimal, but comp legal . What do you guys think. Any suggestions are welcome as I want to keep improving this thing. |
11-06-2009, 08:29 PM | #31 |
RCC Addict Join Date: Jan 2009 Location: O.C
Looks very nice! Quick question for you, do you have to have the front shock position all the way up to run the DMG chassis?
11-06-2009, 08:33 PM | #32 |
Pebble Pounder Join Date: Oct 2009 Location: Dallas
That DMG Tubework is awesome! What does something like that cost if you don't mind me asking, and do you have a link to their website?
11-06-2009, 08:44 PM | #33 |
I think I answered my own question The DmG's / A.L.T Not a bad deal if the price is the same, awesome looking rig! |
11-06-2009, 09:01 PM | #34 |
| Right now mine is set on the 2nd hole closest to the center of the crawler. This is fine for me because I was running the 3rd or middle one before so it wasn't a big change. If someone prefers running the highest setting (furthest away from the center of the crawler) then this might not fit the frame, but you could discuss this with DMG.
11-07-2009, 09:12 AM | #35 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
Love the ALT And I thought I could stop spending money on my lcc. Do you have any issues with the rovers getting stuffed into the front shocks? What is the overall width with the rover/ark combo? |
11-07-2009, 11:40 AM | #36 |
| A little... but way less than the stock foams. The Nova's make the tires way more narrow and taller, which displaces the mass of the tire upward instead of out the sides, which makes contact the shocks. With the Nova's the Rovers are just about the same width as the stock claws. When using the Nova's it is probably more important to focus on using the correct offset in the wheels. If your using the stockers you should be fine.
11-07-2009, 02:18 PM | #37 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
Did you not refit the Rocksmith kit on the tuber for a reason? Kev |
11-07-2009, 04:38 PM | #38 |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
I was going to ask if the dig servo sticks out past the chassis, but it looks like it does from the one pic. I have the same tuber but with the MRC servo for dig and it sticks out too. Looks good though! |
11-07-2009, 08:51 PM | #39 |
Rock Stacker Join Date: May 2005 Location: West Bend
Kick ass thread for a newb like me! Great info and pics!
11-07-2009, 10:49 PM | #40 |
Quarry Creeper Join Date: Oct 2009 Location: Iowa
Sweet build! Thanks for postin' up all the pix too. I check in every night to see what the next upgrade was. I am digging the A.L.T, that looks pretty sweet. I got Rovers and Nova's Ark foams ordered for mine. Also got a proto-type dual stage foams for the Comp Claws. Judging by the pix you posted, I think those will work well. One thing I have noticed in your pix is....it looks like you have an alignment issue (toed out) with the front wheels...or is that an optical illusion? |
