11-05-2009, 08:17 AM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: Alexandria
| Slipper clutch help
How is everyone tightening down the slipper so much?
11-05-2009, 08:38 AM | #2 |
Rock Crawler Join Date: Jun 2009 Location: UK
11-05-2009, 09:58 AM | #3 |
Rock Stacker Join Date: May 2009 Location: chattanooga, TN
I know people keep saying that the slipper is a good thing, but if you really want to get rid of the slip look at this. http://www.liquidrc.com/index.php?ma...ducts_id=60869 It's a metal gear that takes the place of the slipper. I know when I had the axial, the first thing i did was throw the slipper awat, and never had a problem after that. So I don't know why it would be a big deal on the Losi. |
11-05-2009, 10:05 AM | #4 |
What I was meaning is that do I need to take the tranny apart to hold the shaft or it there a trick?
11-05-2009, 10:05 AM | #5 | |
| Quote:
11-05-2009, 10:08 AM | #6 | |
| Quote:
11-05-2009, 10:45 AM | #7 |
Quarry Creeper Join Date: Dec 2008 Location: B.C. Canada
11-05-2009, 11:00 AM | #8 |
| I was trying to hold the shaft still with an allen wrench. One broke allen wrench later I thought that there has to be a better way. Thanks for the info.
11-05-2009, 11:18 AM | #9 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
The best way is to put a .050 hex wrench into the set screw that the slipper nut goes onto, then get a 1/4" open end wrench or a pair of pliers and grab the 1/4" nut. Hold the .050 hex wrench then turn the nut until it's tight. If it works for a little while then the adjustment changes you may need try the following: A) Change the nut, the nylock could be worn out causing it to loosen up. B) Put a shim between the spacer that goes on before the nut and against the slipper ring. The spacer gets smashed too much sometimes and wont tighten down all the way making the slipper loose. C) Drill out the spacer so there is a perfect hole instead of the step-down it has from the factory. Hope this helps. |
11-05-2009, 11:20 AM | #10 |
RCC Addict Join Date: May 2008 Location: Chicago/Bloomington
| You do realize that this gear is the top gear which is inside the tranny. It isn't a replacement for the slipper gear which is outside the tranny. I found that all the problems I had with the slipper coming loose was all due to residual cutting lube in the top shaft. You need to remove the set screw from the shaft, clean both with solvent, use fresh thread lock and reassemble. I replaced the set screw with a 3mm button head screw which means that I either need to disassemble the tranny or use the gear blocking method to tighten the slipper. Fortunately it has not loosened since I repaired it. |
11-05-2009, 11:25 AM | #11 |
Rock Crawler Join Date: Oct 2008 Location: Sandy, OR
I broke off my .050 wrench when I was tightening my slipper the first time and it is still stuck in the slipper screw, so I had to improvise. An easy way to tighten the nut is to put a hex wrench in the driveshaft screw, just like you were tightening it, and hold onto that while using a hex socket wrench to tighten the nut. I actually think this way is easier than any other idea I have tried. Works like a charm, takes about 30 seconds from start to finish.
12-19-2009, 12:23 AM | #12 |
Rock Stacker Join Date: Dec 2009 Location: deroche b,c canada
| tightening slipper
hi there i just bought the losi comp and in ten mins the slipper was backed off.S the trick is hold the small nut on the end off trans and turn the drive shaft by hand you'll need to figure out which direction i can't remeber
12-19-2009, 04:48 PM | #13 |
Pebble Pounder Join Date: Jun 2006 Location: Keizer, OR
i just put a pair of vice grips on the drive shaft and turned the nut with a wrench. after the first half of the first battery, the slipper would not even crawl up a 2" ledge on carpet.
12-22-2009, 11:55 AM | #14 |
Newbie Join Date: Nov 2009 Location: eastridge
I did away with my slipper and love it. |
12-22-2009, 03:20 PM | #15 | |
RCC Addict Join Date: Aug 2009 Location: Earth?
| Quote:
