05-11-2011, 08:08 AM | #261 |
That is a lot of weight in the back. |
05-11-2011, 08:24 AM | #262 |
Looks good. I have been running 3oz in the back of mine for awhile now too. I was thinking a touch more weight would be nice to try.... |
05-11-2011, 09:03 AM | #263 |
Rock Crawler Join Date: Oct 2010 Location: triad
never thought about that much weight out back, but i guess it helps keep it planted. How is it on steep declines?
05-11-2011, 10:12 AM | #264 |
Rock Crawler Join Date: Oct 2008 Location: Italy
05-11-2011, 10:49 AM | #265 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
I bet that's about how much weight is on the back of mine.
03-10-2012, 06:32 AM | #266 |
Rock Crawler Join Date: May 2011 Location: Bama!
| Re: Knuckle weights. Offical thread
Does ne one know if they will work w the rc4wd low boyz?
08-16-2012, 05:51 AM | #267 | |
| Re: Knuckle weights. Offical thread Quote:
My weights, measured with a precision down to about ±0.1 g due to machining differences between samples, the scale is more accurate than that: Bare knuckle weight, with set screw (stainless steel UNC 6-32 x 1/8"): 67.5 g = 2.38 oz Single 0.1" ring: 11.9 g = 0.42 oz Four screws (stainless steel UNC 4-40 x 1/2" countersunk): 2.4 g = 0.08 oz Add together the knuckle weight, two 0.1" rings and a set of screws and the total weight is 93.7 g or 3.31 oz. | |
09-23-2012, 03:51 PM | #268 | |
1) the hub doesn't go all the way in to the knuckle, and 2) the spokes are curved outwards from the hub. With 850 Losi hubs and 22.7mm (just shy of 0.90") added weights it looks like this: The distance between spokes and weight is just about invisible, but at least it's large enough to avoid scratching the paint on the rims... | |
09-29-2012, 11:59 PM | #269 |
Pebble Pounder Join Date: Jul 2012 Location: Portland
Well Olle P, how do you like them so far?
09-30-2012, 04:03 PM | #270 |
I love my knuckle weights. Use about 200g at each front wheel. (Not the standard rings, but home made ones with smaller inner and larger outer diameters.) I've had trouble with my ESC lately though, so I haven't had the opportunity to give the new combo of wheels/foams/weights a real test. Will probably be carried out this week. |
