10-13-2012, 09:53 PM | #61 |
Rock Crawler Join Date: Oct 2011 Location: Corona, CA
| Re: Comp Crawler Build
So on the ends of the worm gear... like so: o ---> []////[] <--- o
10-14-2012, 07:53 AM | #62 |
Quarry Creeper Join Date: Mar 2011 Location: Mn
You don't have to use one internally. Just use one o-ring when the axle is assembled around the metal end of the worm gear that sticks out of the plastic axle case.
10-14-2012, 01:26 PM | #63 |
Ohh, where the 3rd member would be in a sense? Ok
12-10-2012, 12:22 PM | #64 |
Knuckle weights |
12-11-2012, 03:31 PM | #65 |
Quarry Creeper Join Date: Oct 2010 Location: Land of the Cactus
Are you back in az yet? We just finished the first part of the season 2 days ago, but will be going strong again after the new year. Hope to see you there |
12-11-2012, 08:23 PM | #66 |
Yeah I'm back See ya soon! Got back out with the new setup and it did amazing! The grip and added clearance from the rovers helped out a lot. Had it endo a couple of times from the grip |
12-13-2012, 12:44 PM | #67 |
Newbie Join Date: Oct 2012 Location: Prince George, Canada
What knucle wheights are those? Dlux? Looks really good.
12-14-2012, 04:31 PM | #68 |
Yeah they are the Dlux weights. Thank you |
12-14-2012, 08:27 PM | #69 |
So you ready for pro 1 this season? I got a new setup myself, and its workin goooood. Wheres that place you're crawlin? Looks pretty nice. Im ready to see the new revamped lcc do some work |
12-14-2012, 09:47 PM | #70 |
I don't know about that Nice! This was in Gold Canyon.
01-26-2013, 06:20 PM | #71 |
Well I was changing my foam setup and got to thinking why not try the slw hubs on the stock wheels. I used the two short hubs that came with my vanquish wheels and ended up with this Front is not great looking Ended up a little over 10 1/2 in. Little wider than I would have liked but not bad. Need some shorter screws too. On the truck. |
01-31-2013, 08:06 AM | #72 |
Rock Stacker Join Date: May 2007 Location: Ft Stewart
Nice little setup. The more of these build ups I read the more I want to build mine.
01-31-2013, 10:57 PM | #73 |
Thank you I love mine!
02-02-2013, 11:39 AM | #74 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
nice idea on the hubs I broke a couple hubs in the stock rims looks like I can do alittle work and can reuse my rims again thanks for the idea
02-05-2013, 09:59 PM | #75 |
Glad I could help. The wheels have had no problems so far for me. Took the truck to a comp this last Sunday and had a great time. The new front width worked great with only some minor downsides. I was at work the night before messing with mounting the RX and BEC on the front axle. Ran the setup at the comp and it worked fine. This is just a quick first attempt so it will be changed. Had it out a couple days ago testing a new rear link setup. Currently I'm at work to lighten the chassis some more |
02-13-2013, 04:30 PM | #76 |
I finally bent my 6-32 link studs I was using since last year. So I have switched to 8-32 now. 6-32 on the left, 8-32 on the right. Forgot to mention I'm running HD gears in the front now. Currently working on this |
02-15-2013, 06:55 PM | #77 |
Got some parts yesterday. Got the tranny back together and got the idea to cut the gear cover from D lux. Made a brace for the tranny from part of the chassis I cut. Another view. |
02-16-2013, 08:25 PM | #78 |
Got the truck back together. With the tranny flip done there is definitely more forward bias. Had it out today and it was more stable on climbs. I was very surprised how well it handled for changing so many things without any tuning The rats nest I have yet to clean up Bent the rear links. New rear link setup. Used some spacers to push it to just under 12.5 in. Edit: Thanks to Olle P for the idea on the rear upper links. Last edited by TheREDCAT; 02-17-2013 at 07:24 AM. |
06-03-2016, 09:14 PM | #79 |
Well three years later and I caught the itch again to work on this truck... Tonight I was messing around trying to add more weight to the dlux knuckle weights. This thing has been sitting around so long the brass is starting to darken I was trying to make a ring to bolt on to what was already there and in the process I formed a ring that goes around the outside.. Not sure how well this will work out but I ordered some wider slw hubs so hopefully everything clears. |
06-06-2016, 05:26 PM | #80 |
Well I've had two of the Losi carbon fiber shock arms on the back of the truck for a long time now but I wanted all four to be the same. Turns out it's pretty hard to find those shock arms anymore... So I bought a sheet of carbon fiber and made my own! Also the knuckle weights are mounted. Not very pretty but it works. Added about 5 1/2 ounces of weight. They almost clear with 725 slw Hubs so I'm putting 725's in the back and I ordered 850's for the front. |
