Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Tekin redline in a lcc
Old 05-30-2012, 11:21 PM   #1
Default Tekin redline in a lcc
I was wondering if anyone had previous experience running the Tekin 17.5 turn with a mamba Max pro 1 cell esc? What are motor/esc temps like? What is the low end like? And what kind of wheel speed? thanks in advance
K-man74 is offline   Reply With Quote
Old 05-30-2012, 11:46 PM   #2
Default Re: Tekin redline in a lcc
when the heck did you get involved in this?!?!? ahah
and did you get an lcc yet or are you just bullsh!tting around with ideas?
i need to get rid of my rooster crawler 55t combo and put something else in!
crfrider250 is offline   Reply With Quote
Old 05-31-2012, 01:04 AM   #3
Lol rctech thread.
Running a 1 cell in an lcc isn't going to work. It's going to be wayyyyyyy to slow
z50king is offline   Reply With Quote
Old 05-31-2012, 02:41 AM   #4
Why? The 1 cell MMP doesn't have an internal BEC or cooling fan (making it smaller and lighter), but is otherwise the same as the regular MMP.
If anything the LCC should be faster, as a result of the reduced weight...
Olle P is offline   Reply With Quote
Old 05-31-2012, 03:18 AM   #5
that much weight isnt going to make it go noticably faster. you lose the internal BEC and add an external. 17.5t isnt to fast in a LCC. my buddy has an 18.5 turn and its slower than my axial with a 55t in it. you may want to look into something in the 13.5t rang.
crawler nut is offline   Reply With Quote
Old 05-31-2012, 03:29 AM   #6
[QUOTE=crawler nut;3756763]that much weight isnt going to make it go noticably faster.[/qyote]Of course not, but it's definitely not making it any slower ...
External BEC is mandatory anyway to feed a high torque servo when...
... you run it on 4S LiPo?
Old 05-31-2012, 03:35 AM   #7
no way. we like the motors to last a while. lol. even 6s capable motors i only run on 3s, some short 4s runs for fun. im sure its quite a bit faster on 4s. and i was just going off of info given and assuming 3s since it wasnt specified.
Old 05-31-2012, 07:16 AM   #8
Well actually I planed onrunning a 3 cell with external bec and 17.5 is slow? Wow time to go back to the drawing board I guess...
Old 05-31-2012, 07:58 AM   #9
go with the 13.5t you'll be happier with it IMO.
Old 05-31-2012, 08:00 AM   #10
Alright and what is your opinion on the mamba max pro 1 cell?
Old 05-31-2012, 09:08 AM   #11
i run the 1 cell and love it. i have been running it with a novak 18.5t ballistic and it's got plenty of speed. your not going to be jumping gaps or anything, but it has enough wheelspeed to get the job done. i'm running it with a 14t pinion and i can run it about 10 minutes before i need to stop and let it cool down. for comps its fine as we only have a 5 minute time limit per course. i do have a 13.5t that i'm going to throw in and try with a 12t pinion.
as for the mmp 1 cell, i have had no problems with it. i ran it in my wraith, in a honcho, and now in the losi. no heat issues without the fan, and the smaller size makes mounting it easier. the biggest problem with the mmp is getting the sensor cable plugged in fully, the port sits back inside the case a little so if you have some cogging check the cable as one side likes to pull out. i used some small needle nose pliers to push the cable into the port fully and haven't had it pop out again.
one thing to remember is if you use a castle bec, you will have to wire it up per the castle instructions (no direct to servo wiring) as there is no internal bec inside the 1 cell. if your going to run a dig servo i couldn't find a small mini servo that was capable of 7.4 volts, so i set the bec to 6v and run a jr 8711 servo for steering. no reason to buy something like a hitec 7950 as you can't run it on 7.4v.
hoghead5150 is offline   Reply With Quote
Old 05-31-2012, 11:40 AM   #12
Got Worms?
i like the 13.5 alot better than the 17.5...but the 13.5 KILLS battery 1000mah packs
losikid is offline   Reply With Quote
Old 05-31-2012, 11:48 AM   #13
Oh it won't be too slow. I just assumed the CASTLE 1 CELL only worked on 1 CELL
Stupid castle
Old 05-31-2012, 08:33 PM   #14
Well it doesn't need to be blistering fast because it's obviously a crawler but I would like it to be decently fast because I intend to build it as a class 3 scale rig but if it matters I was planning on using either a 2200 mah 3s or a 1400 mah 3s if weight is that big of an issue. But reasoning behind batteries is
A. Their on sale at my LHS
B. l like long runtimes
Old 05-31-2012, 09:31 PM   #15
you may like long run times, but most losi's don't! do some testing and watch the heat of the motor. the tekin 13.5t would be a good choice.
Old 05-31-2012, 10:02 PM   #16
thanks for tellin me they are on sale kyle!
i need to pick one or two or 10 up along with a charger! ahaha
have you got a lcc yet or are you just going off of running mine when it was good? ahah
Old 05-31-2012, 10:06 PM   #17
Yeah Aaron your welcome and I don't have it in front of me but it's traveling from Virgina to me..... Thank god for eBay
Old 05-31-2012, 10:14 PM   #18
well when you get it let me know and you can come run the rock section and trails that we(more jake than me cause of the broken ankle situation i have) made over at his place.
we got vids of mine doing everything his scx10 was doing but mine was in reverse!!!! ahaha
Old 05-31-2012, 10:19 PM   #19
Personally I think the 13.5 is too much on 3 cell. 17.5. On 3 cell would be my choice with a fair amount of timing added at upper rpms. Keeps the low end and great top end. I run a 21.5 with tekin rs pro, but 17.5 has been on the list.
skid is offline   Reply With Quote
Old 05-31-2012, 10:20 PM   #20
Not going to lie sounds pretty epic. But I have quite a while ( 1 month) until I can afford everything. But the motor esc and crawler should be put together next week. And then 100 for a 3 ch. controller and 80 for a servo and then a 150 for 2 lipos and dual charger so yeah it's like 800 and I have like 450 so it could take some time and then after that I will save more for DIG and there will probably be more parts broken Then good when it first hits the rocks
Tags
17.5, castle creations, lcc, redline, tekin
Tekin redline in a lcc - Similar Threads
Waterproofing A Tekin Redline sixhundred71 Electronics 2 06-01-2012 06:43 PM
