Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Need help with my losi comp crawler
Old 08-04-2013, 02:51 PM   #1
Default Need help with my losi comp crawler
I have recently got a losi comp crawler. I have a castle micro sidewinder with ao 55t Novak motor. When's crawling up somthing steep it just Boggs down. I'm runnin a 14t pinion. What can I do, please help me!!!!!!!
BigSid00 is offline   Reply With Quote
Old 08-04-2013, 04:47 PM   #2
Default Re: Need help with my losi comp crawler
One of the first things I would recommend would be to lube the worms. Jerry
jgrim is offline   Reply With Quote
Old 08-04-2013, 06:16 PM   #3
Is there anything holding the dig in place?
Sent from my PG86100 using Tapatalk 2
z50king is offline   Reply With Quote
Old 08-04-2013, 10:55 PM   #4
The micro sidewinder might not be a powerful enough esc for the Losi.
rangercat23 is offline   Reply With Quote
Old 08-05-2013, 11:23 AM   #5
WAM
I think the esc and motor should be adequate. LCC trannys are geared higher, so a 12T pinion wouldn't hurt. How's the battery? What voltage, capacity, and have you checked the voltage after a little runtime with a voltmeter? Do you have an external bec for the steering servo? If not, pull the servo plug and drive it up a steep without steering just to see if that matters. And if you're new to losi's, take note of jgrim's point. Worm lube is a big deal on these cars. Check back when you're sure the lube and battery are fresh.
WAM is offline   Reply With Quote
Old 08-05-2013, 01:16 PM   #6
ZiG
There was also a bulletin way back about extra shims being shipped with the LCC axles that caused a bunch of extra drag because they would cause the worm gears to bind up. Might want to check that out and see if yours was one of the affected ones.
ZiG is offline   Reply With Quote
Old 08-07-2013, 06:30 PM   #7
Worm gears are lubed, im running a 3s 800 mAh battery 11.1v. Just bought me a novak 35T motor. Would a night crawler tranny give me lower torque. I dont care if i loose dig cuz we cant use it in our shafty class
Old 08-07-2013, 06:46 PM   #8
WAM
Yes, most comp guys fit LNC trannys which are a straight bolt-in. They're lighter, compact and much lower-geared. Unless you happen to find one, they can be easily and cheaply built from new parts available from EBAY. Figure about $25-30.
Was the 55T motor bad?
Old 08-08-2013, 05:37 PM   #9
No, i just want more power
Old 08-08-2013, 11:56 PM   #10
What is your radio epa setting? Just curious?
xxx123 is offline   Reply With Quote
Old 08-09-2013, 06:49 AM   #11
Here's a link to a great thread about lessening the friction in the drivetrain of a Losi crawler. Good stuff.
Tip: How to reduce the friction in LCC and LNC.
strato54 is offline   Reply With Quote
Need help with my losi comp crawler - Similar Threads
New to the Losi Comp Crawler or Losi Night Crawler - Post your questions here! Mad Dawg Team Losi Comp Crawler 355 05-14-2023 06:43 PM
