Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: LNC Transmission an Pinion Gear Question!
Old 03-17-2014, 12:28 PM   #21
Default Re: LNC Transmission an Pinion Gear Question!
Originally Posted by Olle P View Post
I think that depends on the specific motors used and the timing limitation of MMP.
- Typically using the same timing on a few pole inrunner and a multi pole outrunner will make more of a difference on the inrunner. (But for my inrunner motor 20 degrees of timing, the MMP maximum, is considered to be "a little".)
- With zero physical timing on the sensor the behaviour should be the same in SMART and CHEAT mode, given that the same high speed timing is set. SMART is supposed to work better, because the ESC's electronics can have a hard time keeping up at high sensor speeds.
Anyway, I'm now waiting for the Revolver S to come back in stock so I can order one and find out for myself.
Ok so Im a little tight on money right now and the setup is a Integy 35t brushed motor with a 2000mah 2s lipo battery with a 20t pinion. Now if I wanted to get a little more wheel speed I would reduce the size of the pinion right?
murlin12 is offline   Reply With Quote
Old 03-17-2014, 05:01 PM   #22
Default LNC Transmission an Pinion Gear Question!
Smaller p-more torque/less wheel speed
Larger p-more wheel speed/less torque
If u want to stay cheap and brushed keep your 20t pinion and go get a Titan 21t 550 motor and toss that in. Will I've you more torque and wheel speed. It is like 20$ or so.
Liv3mind is offline   Reply With Quote
Old 03-18-2014, 06:42 PM   #23
Alright thanks man! Ya Im gonna keep it brushed right now, but when I go brushless and get a new esc, I have no freaking idea where to wire things up!!!
Old 03-18-2014, 09:42 PM   #24
The Titan is a brushed motor. It is a 550 can, meaning bigger motor. More torque.
WHEN you do decide to go brushless, hit us up, we are glad to help. There are alot of wires, and alot of choices....most bad. We will help you not make the mistakes we did.
dentonmac is offline   Reply With Quote
Old 03-19-2014, 01:08 AM   #25
^what he said "thumbs up"
Old 03-19-2014, 05:10 AM   #26
Alright thanks guys! Ill post some picks of the set up at this piont!
Old 03-19-2014, 09:32 AM   #27
I am running the Titan setup in my extra lnc still. It's heavy but cheap and powerful
Old 03-19-2014, 02:58 PM   #28
Awesome! yea this Integy 35t just dosent have the wheel speed (the pop!) dont get me wrong its got tons of torque tho!
Old 03-19-2014, 08:20 PM   #29
The JENS LNC Tranny mod (mentioned earlier in this thread) might also be a good option to get some of that pop back out of the brushed motor.
It increases (or decreases - I can't remember) the ratio like you are running a much larger pinion (so you get the wheel speed), but it does not seem to lose the low end or heat up the motor that comes with running a much larger pinion.
So far i am pretty impressed.
Edit: Just thinking after I posted this, the mod might bring brushed motors back into play as a viable option for the Losi....Might
Old 03-20-2014, 04:57 AM   #30
Thats a good Point!
Old 03-20-2014, 06:19 AM   #31
Here are some pics!
Old 03-20-2014, 10:04 AM   #32
Great start. Work on getting the battery and electronics closer to the axle. The chassis is convenient to place everything, but the worst place to do it. All that weight is up high (Center of Gravity), and sprung (springs having to work the suspension as well as support that weight). With the tiny FXR and small batt, it should be much simpler. Hope that makes sense.
Love the Sedonas. Get some more miles on those things, and wash them with Simple Green and they will really come to life. I got my set used (very used) and just was going to run them until I go a new pair. I got a new pair, and ended up putting my old ones back on. I liked the old ones so much, that was two years ago.
Old 03-20-2014, 07:19 PM   #33
Ok, what is simple green and where you get some? Also I have been poltting and thought on the subjec matter of moving things around. Like I said, Im kinda low on $$$ right now ( still in school) so ill be making a parts list and researching/asking questions in the time being.
Old 03-20-2014, 08:05 PM   #34
It's an all purpose cleaner, next to the spray cleaners at any grocery store
Old 03-21-2014, 06:04 AM   #35
Sweet, an you just spray that on the tires and let it sit/dry?
Old 03-21-2014, 12:23 PM   #36
Yes, I spray it and rub them down to clean them. Then hit them again and let them sit wet for at least 12 hours.
Old 03-23-2014, 12:06 PM   #37
Ok great! Now ive been intensiveley reading on the all the comp crawler forms and the major brand of suspension I see is the Traxxia Big Bore shocks and I have some of those, are they what you want for comp crawling.....whats there purpose?
Also what is the best way to put my battery (as seen earlier in the thread) onto the axles? Is there an aftermarket batt tray?
Lastly what is the best way to lengthen the axles....like, is there spacers you can buy or will I have to manafacture them?
Old 03-31-2014, 06:53 AM   #38
... The more 'poles' a motor has the less it takes to timing advance.
It's a matter of definition. (Had a lengthy discussion about this subject on another forum.)
If you define the timing angle by how many degrees the motor axle rotates (typical endbell timing) you're correct.
The normal way, however, is to define timing in terms of ("ignition") cycles, of which there are more per axle revolution the more poles there are. (A 14 pole motor has seven cycles per axle revolution.)
Each cycle is seen as one 360 degrees revolution.
Timing is added to make up for delays in "current on" due to electromagnetic and and semiconductor phenomena. This delay (as measured in "per cent of cycle") is typically larger for multipole motors than for low pole motors.
Hence you can typically use more timing for a multipole motor than for a two-pole.
The Revolver motors are 14 pole (I think). That is one of the reasons I have stuck so long with the 2 pole motors.
More poles = Better!
* Smoother at low speed.
* More torque.
* More efficiency.
(Less motor top speed is no disadvantage here.)
Olle P is offline   Reply With Quote
LNC Transmission an Pinion Gear Question! - Similar Threads
Question about Pinion gear specv1113 Axial Wraith 3 01-23-2013 10:26 AM
Disruptor Transmission Pinion Gear??? heinie_21 General Crawlers 0 09-03-2012 11:55 PM
Transmission question LNC/LCC woodsracer673 Newbie General 2 09-13-2011 09:59 PM
