Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: New to a LCC but also have a LNC 2.0...Recommendations?
Old 09-09-2016, 05:33 AM   #21
Default Re: New to a LCC but also have a LNC 2.0...Recommendations?
where did you get that body...
CM9000 is offline   Reply With Quote
Old 09-11-2016, 08:45 AM   #22
Tib
I picked it up from Horizon Hobby
Grappler Pro Body, Clear with Stickers & Mask | HorizonHobby
Tib is offline   Reply With Quote
Old 09-11-2016, 08:51 AM   #23
Tib
The grappler body is a solid body.
First attempt at using a mask/doing flames. Had my 4 year old help...didn't turn out bad all things considered.
Had a blast with the kid so that's what counts.
Old 09-11-2016, 11:20 AM   #24
mrG
Yup grappler pro is a great body. Nice blue btw
mrG is offline   Reply With Quote
Old 09-13-2016, 12:02 PM   #25
nice blue. and yeah I see they are in stock. just wondering why mine from fast serve (horizon dealer site) still has 3 of mine on backorder.
good body to put on any shafty rig in my opinion.
Old 09-24-2016, 11:52 AM   #26
snapon boy's Avatar
Ok have been reading and saw a few posts that say if you have the lnc transmission you can run brushed motor and if you have the lcc you need brushless. I'm planning on building my son a comp rig and wanted to use hh puller and b mini. Is that not going to work for the long haul?
149 r/c worx team driver
snapon boy is offline   Reply With Quote
Old 09-28-2016, 05:03 PM   #27
Tib
Well completed the build...or should I say temp build.
I ended up ordering a HobbyWing 10BL60 Sensored ESC and Quicrun 17.5 Sensored Brushless Motor. This is the temp setup since I'm going to put this to our LNC 2.0, in a month or 2.
Put in a SRS4210, 16 tooth Pinion, and the LCC rear upper link mount. Put everything together for a test drive and works suprisingly well for budget build.
I need to clean up the wiring but for a quick run, I didn't worry about it.
Old 10-05-2016, 02:59 PM   #28
How is that ESC working for you I had one in my wraith and it only lasted a couple days before it started acting like lipo cut or thermo shut down constantly. Was considering another one but wasn't thrilled with the first one.
mindless is offline   Reply With Quote
Old 10-05-2016, 03:29 PM   #29
Tib
So far so good, but I haven't ran it too much.
So far I have ran 2 packs on it, in the house. They are 2S 2600mah 90C lipos.
Did you check the fan connection or capacitor leads, maybe one disconnected
I run a Hobbywing 60A esc in my TC3 and have ran tons of packs thru it without any problems.
Old 12-05-2016, 05:22 PM   #30
mindless, Try a new sensor wire.
gmorg is offline   Reply With Quote
New to a LCC but also have a LNC 2.0...Recommendations? - Similar Threads
???lnc/lcc??? mudd_slinger Team Losi Comp Crawler 4 10-06-2013 09:46 PM
lnc to lcc heminutt Team Losi Comp Crawler 7 10-03-2013 04:09 PM
LCC vs LNC TOYUTAH Team Losi Comp Crawler 9 01-15-2010 08:04 PM
