11-11-2016, 09:47 PM | #41 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Jrs losi shafty slow build
Well tonight dad and mom went to a tech expo on milling machines and 3d printers etc (free beer street tacos and burban Pecan pie with vanilla ice cream) long story short the sitter had the kids passed out when we got home. So I got out the hakko and started on the smash for the esc . I've got to get some cambric tape and heat shrink and 2 more coats of conformal coating. Then it will be done. were hoping to be driving tomorrow after the mail lady brings the Holmes Hobbies box!..... 149 r/c worx's Team Driver Last edited by snapon boy; 11-11-2016 at 09:51 PM. |
11-12-2016, 05:15 AM | #42 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
I need to get on my tire game...lol..and after seeing that chassis .......guess I need one too at some point!! It's really nice to see you and your son working on this...he will remember these things!!! Sent from my HTC One M9 using Tapatalk Last edited by dasco; 11-12-2016 at 10:54 AM. |
11-12-2016, 07:40 AM | #43 | |
Pebble Pounder Join Date: Mar 2016 Location: Harrisburg/York
| Re: Jrs losi shafty slow build Quote:
Looks great, makes me want to pick up the chassis and links. | |
11-12-2016, 06:39 PM | #44 |
| Re: Jrs losi shafty slow build I've got to say blue monkey came threw and shipped on time and arrived just in time for jrs 1st comp. These weights are a very nice product! I will be ordering the tuner set as well soon. 149 r/c worx's Team Driver Last edited by snapon boy; 11-13-2016 at 08:38 PM. |
11-12-2016, 06:43 PM | #45 |
Well I've got to do some troubleshooting. One axle got up to 150 degrees in 2 laps around the living room. The other was up 90. I filled the housings with grease I don't think I over tightened them. I've got massive amounts of torque twist but it climbs well and the speed is just right for Jr. 149 r/c worx's Team Driver |
11-13-2016, 07:06 AM | #46 | |
Pebble Pounder Join Date: May 2016 Location: Warwick
Sent from my HTC One_M8 using Tapatalk | |
11-13-2016, 08:39 AM | #47 |
Some heat is normal snap...but that's up there..check the shim placement on the worm gear. They often are wrong. Sent from my HTC One M9 using Tapatalk |
11-13-2016, 04:18 PM | #48 |
I found the binding spot the drive shaft was rubbing. I need some losi comp crawler drive shafts or something similar anyone have a suggestion. The stock losi is just a bit short. 149 r/c worx's Team Driver |
11-13-2016, 04:27 PM | #49 |
Hey, I have the krazed builds rear plate also and with the stock driveshafts I had to shave very little of the plate above the rear driveshaft. I have switched out my driveshafts now so there is no rub when compressed. Using the lnc drive shaft in the front and an S.D.I in the rear which can be shortened. I'll try to get a pic up later but you can find the S.D.I driveshafts on a search here I'm sure. Sent from my HTC One_M8 using Tapatalk |
11-13-2016, 04:29 PM | #50 |
Super! 149 r/c worx's Team Driver |
11-13-2016, 04:48 PM | #51 | |
In our LNC, the rear gets alot hotter than the front, BUT been that way since new out of the box and barely shows any wear. Now on the LCC, both never get warm. Are they shimmed correctly? IIRC you can adjust them by installing or removing shims. LOSA6358 is the shim set. | |
11-13-2016, 04:49 PM | #52 |
| Re: Jrs losi shafty slow build |
11-13-2016, 04:50 PM | #53 |
Hitec 5955 and a Vp Servo cage 149 r/c worx's Team Driver |
11-13-2016, 08:16 PM | #54 |
I got Jr a set of Sdi propeller drives shafts headed this way and hit up Holmes Hobbies for a micro momba x sensored brushless esc to use with my 13.5t sensored motor. 149 r/c worx's Team Driver |
11-13-2016, 09:21 PM | #55 | |
11-13-2016, 09:38 PM | #56 |
What motor did you pick to run with your momba micro x? Have you got a set of the 20 degree knuckles or chubs yet? 149 r/c worx's Team Driver |
11-14-2016, 07:43 AM | #57 |
I got a 17.5t D4 1S Short Stack Maxzilla with the extra torque which was recommended to me and its a nice motor. Mine had the hot racing chubs/knuckles on it until a day or 2 ago when I did the XR mod. Sent from my HTC One_M8 using Tapatalk |
11-14-2016, 07:59 AM | #58 |
Did the 20 degree knuckles help any? 149 r/c worx's Team Driver |
11-14-2016, 03:09 PM | #59 |
I think they are 10' and can't compare because I got it off the classifieds with them on already. PM me if your interested in them. Sent from my HTC One_M8 using Tapatalk |
11-14-2016, 06:18 PM | #60 |
Well I got some jato rod ends and a few other things to finish up jrs rig from Rrp Hobbies amazing fast shipping happy customer! I have gotten all the links where I want them and centered the front wheels. I think I'm going to get the tuning set of weights from blue monkey to go ahead and load up the front. I got Jr a 16.5 hobby wing motor to hold him over till dad can afford a brood or Holmes brushless motor. 149 r/c worx's Team Driver Last edited by snapon boy; 11-14-2016 at 06:20 PM. |
Jrs losi shafty slow build - Similar Threads | ||||
Austin's Slow SCX-10 build Turned Slow Wroncho build | austinc2099 | Axial SCX-10 | 35 | 10-25-2018 09:38 PM |
Slow steady Losi MRC Build up | GhettoFabwork | Losi Mini-Rock Crawler | 4 | 04-12-2011 07:21 PM |
Shafty or MOA Losi build? | Mikeney | Team Losi Comp Crawler | 8 | 12-26-2009 08:12 PM |
