12-12-2016, 05:35 PM | #81 | ||
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Jrs losi shafty slow build Quote:
Ernie | ||
12-12-2016, 05:41 PM | #82 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Erie you have a pm. 149 r/c worx's Team Driver |
12-12-2016, 06:43 PM | #83 |
| Re: Jrs losi shafty slow build |
12-15-2016, 04:46 PM | #84 |
Nice build and great to see father helping son, mentoring, building RC cars and having fun! I remember my Dad helping me with projects and me 'helping' him with some of his projects, good times! Keep us updated. Ernie, sounds like an interesting steering challenge. |
12-16-2016, 09:23 AM | #85 |
It will be, but snapon boy and I have been putting our heads together and think we have it figured out on paper. Now, the proof will be in the pudding. If I could get a few more users on board I would be willing to put a little $$$ into R&D. And found out he has some great Dutch oven dishes!!!! Ernie Last edited by CODYBOY; 12-20-2016 at 09:29 AM. |
12-16-2016, 12:36 PM | #86 |
I can't see why others would not want in on it! 149 r/c worx's Team Driver |
12-16-2016, 04:41 PM | #87 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
I would be interested, but here are my concerns. 1. Another father of two here. Cost is an issue. 2. I have run STOCK Losi axles in every single scale crawler ive built since 2009. The only failures ive EVER had were a set (1 set!) of stock worms due to lack of lubrication, V1 axle shaft, and one axle shock mount. Thats it! (CVD Pins dont count ) My point is, in all these years of trail rides, G6's, TTC's and SORRCA Comps, My axles have been BULLETPROOF! And I attribute that to Losi's Engineering. The Axle Housing / C-Hub / Kingpin and Knuckle design, IMO, are practically flawless. The way the C-Hub fits over the housing ears and bolts through the face, deep into the plastic is key! I have seen failure, upon failure, upon failure of Axial based rigs at these competitions due to the C-Hub / Knuckle design. Even rigs running Beef Tubes and Aluminum Upgrades. Yes, Vanquish too . Everyone that I have seen attempt the XR-Mod (T.A.G., Youngblood, That dude from Australia) cut off these ears and machine a slip fitting over the axle housing (with splines for the Axial style C-Hub) secured with grub screws. IMO, Its another failure waiting to happen. Especially now that Scale Comp builders are taking notice of these axles. Scale rigs are generally heavier and subjected to environments MUCH more harsh than a Pro-Shafty. 3. Axle shafts need to be complete RTR. Either machined 1-piece, or welded. Many "bolt-on kit buyers" don't have the capacity to MIG, TIG, or even measure. T.A.G. had a sleeve for the two axles to be secured with red loctite. Ive heard of a few coming loose. The Aussie had a similar sleeve, but used grub screws to hold the axle halves together. Youngblood has (my personal) favorite solution, but it involves welding. 4.*(A Scale Point of View)* The XR-Mod adds width to the Losi axle. For SORRCA Comps, these gates can be extremly tight! Many prefer a "Narrow XR MOD" for this reason. Just a thought. 5. *(Another Scale Point of View)* The stock Losi axle gives 45* of steering throw. In a Scaler, with full frame rails, shock placement can be tough. Tire rub is a real issue. I have been able to "max-out" my stock Losi steering, however...getting more than 45* is gonna be tough. Even if you could manage 55* of throw with an XR-Mod, would it be worth the effort? Thats why, after all these years, I've never bought a Losi XR Kit. I could never justify paying $100.00 to compromise a Bullet Proof Axle Structure, futzing around hacking together two unlike shafts, just to gain (maybe) 10* of "useable" steering throw. Not trying to be all Doom & Gloom, but even with Scale thrown into the mix. The amount of people actually USING Losi Worm axles in Scale are probably the same numbers as those still using them in Shafty. Not Many! I bet we all know each other! Lol |
12-16-2016, 08:43 PM | #88 | |
Ernie Last edited by CODYBOY; 12-16-2016 at 09:43 PM. | |
12-18-2016, 10:12 AM | #89 |
Hey snapon boy, work on the axle mod some after we got back home yesterday, getting close to a design concept. I need to order some parts from McMasters Carr and RPP to wok on a proto type. Right now they will be pretty close to stock width (8.25) from stub end to stub end. I know width was a concern of GIjoe so tried to address that. Strength was a concern, so tried to step out of the box a little. When I have a little more of the idea put together I will sent some photos. Like GIjoe mentioned, this may only interest a hand full of Losi guys. Ernie Last edited by CODYBOY; 12-20-2016 at 09:39 AM. |
12-18-2016, 11:11 AM | #90 |
Ok sounds good. No rush. 149 r/c worx's Team Driver |
12-18-2016, 11:17 AM | #91 |
Jr has shift hubs so width isn't a big deal 149 r/c worx's Team Driver |
12-18-2016, 01:09 PM | #92 |
Rock Crawler Join Date: Apr 2010 Location: Eastridge Tn.
Interesting ideas here guys...I'm intrigued!! Sent from my HTC One M9 using Tapatalk |
12-18-2016, 01:14 PM | #93 | |
This set up would come with housing, as I need to mod them a little. Ernie | |
12-18-2016, 01:39 PM | #94 |
Ok. Will you be using the losi chub or axial? I got the blue monkey brass weights now. However they can be sold. 149 r/c worx's Team Driver |
12-18-2016, 01:57 PM | #95 |
Jrs losi shafty slow build - Similar Threads | ||||
Austin's Slow SCX-10 build Turned Slow Wroncho build | austinc2099 | Axial SCX-10 | 35 | 10-25-2018 09:38 PM |
Slow steady Losi MRC Build up | GhettoFabwork | Losi Mini-Rock Crawler | 4 | 04-12-2011 07:21 PM |
Shafty or MOA Losi build? | Mikeney | Team Losi Comp Crawler | 8 | 12-26-2009 08:12 PM |
