05-02-2013, 07:10 PM | #1 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Sanding Tires...
Hmm this looks cool... I know it's for bodies but it looks like it might be a good thing for shaving sidewalls on tires... What do you guys think? Introducing a brand new product line from PROTOform: the Better Edge System. For every r/c enthusiast that takes pride in finishing off their concours-worthy race body, these products are for you. The Better Edge sanding drum is our first product in this line. There has never been a product specifically made for r/c racers to finish off the perfect wheel-well. With the use of your handheld rotary tool, the Better Edge Sanding Drum will smooth out all of the imperfections left from cutting your lexan body with scissors. At 1.5” in diameter, it’s suitable for use on many scales of body: from 1:12 scale on up to 1:8 or even off-road bodies. The drum’s red and black anodized aluminum finish and laser-etched PROTOform logos give it a trick look on your pit table. Each pre-assembled kit comes with a replaceable high-grade silicon carbide spiral sanding band, rubber anti-slip o-rings and a mandrel made from durable tool steel to prevent damage from your rotary tool’s chuck. Give your r/c race body a better edge! Features • Made specifically for finishing lexan r/c body wheel wells • Signature trick PROTOform style • Produced from high-quality anodized aluminum and steel • Just slide the sanding band over the drum and screw on the retainer ring. (Finger tight is all you need, no wrench required) Dimensions Drum Diameter: 1.5” (38mm) Drum Width: 1” (25mm) Mandrel Diameter: .125” (3.2mm) Mandrel Length: 1.125” (29mm) What’s Included • Anodized 6061-T6 Aluminum drum (1 pc) • Anodized 6061-T6 Aluminum drum cap (1 pc) • Tool Steel mandrel (1 pc) • 120 Grit Silicon Carbide Spiral Sanding Band (1 pc) • Rubber o-rings (2 pcs) Part #: 6103-00 PROTOform Better Edge Sanding Drum for Handheld Rotary Tool |
05-02-2013, 07:25 PM | #2 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
| Re: Sanding Tires...
I have about 20 sanding drums for my dremel and none of em cost 28$
05-02-2013, 09:19 PM | #3 |
Newbie Join Date: Apr 2013 Location: Newberg
I second that. $28 seems too much.
05-03-2013, 08:21 AM | #4 |
| Re: Sanding Tires... |
05-03-2013, 08:27 AM | #5 |
Depends on how effect it is for $28. Might be worth it. I bought one of these a year or so and like it. Belt Sander with 1'' X 30'' Sanding Belt |
05-05-2013, 06:54 AM | #6 |
Quarry Creeper Join Date: Jan 2008 Location: Granite Falls, WA
i do like that its large. small sanding drums can be a pita so get teh wheel wells correct. but yeah @ $28 i dont think ide buy one.
Sanding Tires... - Similar Threads | ||||
Sanding plastic wheels | 47willysbuggy | Tires and Wheels | 4 | 07-01-2009 12:43 PM |
Wet Sanding | Norcal crawler | Paint and Body | 12 | 01-16-2008 04:42 PM |
Sanding Sidewalls? | CoolManLance | Tires and Wheels | 10 | 03-31-2007 07:24 PM |
sanding....help please!!!!! | snook | Tools, and Procedures | 10 | 01-01-2007 11:19 PM |
Sanding aluminum? | Zombie76 | Chit Chat | 5 | 09-10-2005 04:28 PM |
