Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: only cut tires. post up your cut tire photos
Old 11-16-2014, 02:45 PM   #101
Default Re: only cut tires. post up your cut tire photos
cutting all of the little ribs off, made this 1/16 craw like the big boys
kgb424 is offline   Reply With Quote
Old 11-21-2014, 09:31 AM   #102
I'll have to try this with my Trep's, not impressed with them so far.
Is there any benefit to not cutting the middle treads on the Trep's? I've seen some people cut them, some don't.
flifisher312 is offline   Reply With Quote
Old 11-21-2014, 12:44 PM   #103
I thought it did wonders for the treps opening up the middle. Allowed them to clean out faster and easier. Also improved grip on rocks for me. My rig is mostly slow crawling tho so I guess it may depend on how you plan to use them.
Crawlin' Lobster is offline   Reply With Quote
Old 11-22-2014, 11:18 AM   #104
Default only cut tires. post up your cut tire photos
My first try at cutting tires and I did this to my U4's. It's a bad pic lol.
First I wanted more space on the outside lugs to help it in the dirt... So I removed all the smaller lugs. Then I trimmed the remaining outside lugs down on the edges so they don't catch as easy while drifting in the dirt. I then cut an angle out from the center lugs to give a little more void without cutting too much out. I also cut an angle on the outside edge of the center rows again to give a little extra space.
kind325 is offline   Reply With Quote
Old 11-27-2014, 08:29 AM   #105
this is an update of a previous cut/sipe design, cut outer lugs in front then cut rears to paddle like setup
front
rear
mods made tire very soft and conforming but digs holes very fast if movement stops in loose dirt. want to try some TTC stuff or formula off road w these.....
domofthedead is offline   Reply With Quote
Old 11-27-2014, 07:58 PM   #106
I joined the Band!
Has anyone cut up the new 3.8 BFG Krawlers yet? I'll be picking up a set to try in a week or so.
I was thinking of just siping the tires? what do you think?
twissted is offline   Reply With Quote
Old 08-15-2015, 09:02 AM   #107
Box stock BFG Krawler T/A's. Called a snow cut or a scramble cut.
Geezer is offline   Reply With Quote
Old 08-15-2015, 10:05 AM   #108
I joined the Band!
I cut My 40 series tires to fit the 1/5 beadlock wheels. I don't run foams in the Mud slingers because of the much stiffer side wall. They are my favorite tire on the Ravon 5 spoke rear wheels. The off set is spot on!
Here is the difference in the inside wheels fron the 1/5 and stock.
I'm getting better performance from the tires and the wheels are bomb proof!
Old 08-15-2015, 12:54 PM   #109
"GOD SPEED"
voodoo u4 w/ mayhem g10 wheels.
Sent from my SAMSUNG-SM-G870A using Tapatalk
nerby149 is offline   Reply With Quote
Old 11-30-2015, 12:45 PM   #110
Location: Taylors Falls just hanging with the MNRCRC crew.
It's interesting that no ones cut a Pitbull Growler yet?
Stormin2u is offline   Reply With Quote
Old 11-30-2015, 07:53 PM   #111
They have just not in this thread.
fr8cture is offline   Reply With Quote
Old 12-01-2015, 09:15 AM   #112
If you check out Crawler Innovations on Instagram, they have a couple different cuts they've done on Growlers.
Edit: Found in the Beastly Beauty thread...
Sneetches is offline   Reply With Quote
Old 12-05-2015, 07:43 AM   #113
Tire&Foam Extraordinaire
Nova's Ark's Avatar
Rims: 1.9" Vanquish Products 8 Hole Shooters Bead Locks
Tires: Cut 1.9" RC4WD 4.19" Baja Claw
Foams: Crawler Innovations 4.25" Lil' Nova Comp Cut Inner with Medium Outers
..Uploaded from the lab @ the C.I. Compound...
Nova's Ark is offline   Reply With Quote
Old 12-05-2015, 07:46 AM   #114
Nova's Ark's Avatar
Rims: Crawler Innovations 6 Bolt Wheels in the 1.50" Width
Tires: CI Cut Pitbull 2.2" Growlers
Foams: CI 5.5" Double Deuce Comp Cut Inners with Medium Outers
Old 12-05-2015, 07:50 AM   #115
Nova's Ark's Avatar
Not cut in your typical way but meh...
Rims: rare Vanquish Products 2.2 / 3.0" Short Course Bead Lock Set
Tires: Cut 3.0" bead RC4WD TTC Baja Claw Radial Tire Set
Foams: Custom CI Double Deuce dual stage foam set
Old 12-05-2015, 07:56 AM   #116
Nova's Ark's Avatar
Rim: Axial 3.8" Bead Lock
Tire: Cut RC4WD Mud Slinger
Foams: Crawler Innovations Deuce's Wild part no. CWR-3009
Old 12-05-2015, 08:01 AM   #117
Nova's Ark's Avatar
Tires: RC4WD Bully 2.2 Comp Tire
Foams: 5.25 Double Deuce Comp Cut Inners, Soft outer front, Medium outer rear
Old 01-08-2016, 09:54 PM   #118
Hotrodvw is offline   Reply With Quote
Old 01-11-2016, 09:51 PM   #119
2.2 Traps
Nalleywhacker is offline   Reply With Quote
Old 03-15-2016, 05:05 PM   #120
Sent from my SAMSUNG-SM-N910A using Tapatalk
Madatl is offline   Reply With Quote
only cut tires. post up your cut tire photos - Similar Threads
Dove cut, bobbed, cut, chopped, you name it its been threw it... California Raisin... Madjones Losi Micro-Rock Crawler 6 11-17-2014 09:07 AM
Post your cut tires here. AXLE 69 Tires and Wheels 0 11-10-2013 05:12 PM
post your cut stock tires Steelfish HPI Wheely King 1 05-21-2013 11:22 AM
*** proline flat irons to cut or not to cut you tell me *** Cmace23 Tires and Wheels 14 01-21-2012 12:33 AM
Post Pics Of Your Cut Stock Clod Tire Xtremekrawler8 Tires and Wheels 5 05-03-2005 09:05 PM
