03-15-2016, 09:56 PM | #121 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
| Re: only cut tires. post up your cut tire photos
3.8" Krawlers Voodoo U4s 2.2" MudSlinger XLs |
05-17-2016, 08:42 PM | #122 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
Proline Flat Iron XL 1.9: |
02-03-2017, 03:08 PM | #123 |
Rock Stacker Join Date: Jan 2017 Location: Houston
| Re: only cut tires. post up your cut tire photos |
02-03-2017, 03:12 PM | #124 |
Since we're talking about cutting here, what's the best way, and easiet way to cut them.? I have a dremel but I've heard other methods. Sent from my SAMSUNG-SM-G530AZ using Tapatalk |
02-03-2017, 11:28 PM | #125 |
Newbie Join Date: Apr 2014 Location: Adelaide
I cut the grooves with the Dremel. For cutting the lugs off I bought a pair of nibbler pliers. Sent from my XT1068 using Tapatalk |
02-03-2017, 11:42 PM | #126 |
Dremel with a variety of accessories and nippers work for me. 2.2 Jconcepts sporpios with the ribbing cut off the inside and buffed the carcass thin then shaved the outside. Grooved the hell out of the tread too. Every lug got modified or removed. 2.2 jconcepts ruptures. Shaved the sidewalls, buffed them thin and cut huge amount of reinforced bead area off so the tire flexes. I'm sure they hold their shape in U4 but that's not the hot ticket for crawling. |
02-04-2017, 12:42 AM | #127 |
Ok thanks for the tips guys. I have a dremel and some accessories for it I made need a few more, and I have regular snippers but I think I might have to get a small pair. MyGreenScx10 |
02-04-2017, 08:52 AM | #128 |
Pebble Pounder Join Date: Jan 2014 Location: Rochester
Did you sand the sidewalls down? Or actually shave off material some how? I Narrowed a set of Ruptures for my MOA, but did nothing to the sidewalls.
02-04-2017, 09:34 AM | #129 | |
| Re: only cut tires. post up your cut tire photos Quote:
I've been happy with both sets of jconcepts tires but it took a good bit of work to get here. They keep up with voodoo's so I'm happy. | |
02-04-2017, 09:39 AM | #130 | |
Very nice. I think I will give it a try, I was thinking of using sandpaper and laying it on a flat surface. Then rubbing the tire sidewall on that in a figure eight pattern to get even sanding. I will have a firm tire foam in the tire too. Sent from my iPhone using Tapatalk | |
02-04-2017, 09:45 AM | #131 |
You'll never get it perfectly even since the tires have thick and thin spots from the start. I use this bit in the dremel and hold it like a big crayon coloring the side lugs away. Then I go over the whole sidewall with the stone laid flat to take a bit of material off the rest.
02-04-2017, 11:53 AM | #132 | |
Okay I will try that instead, thanks for the advice. Sent from my iPhone using Tapatalk | |
02-09-2017, 07:57 PM | #133 |
Okay I thought I would post these up as a work in progress. Jconcepts Ruptures, narrowed and started shaving the tread off the side walls. Using the dremel with a sanding drum seems to be working. I'm going to try the sanding stone to see if it will give the tire a nice smooth finish. Sent from my iPhone using Tapatalk |
02-09-2017, 09:12 PM | #134 |
I wanna be Dave Join Date: Dec 2006 Location: here
02-16-2017, 10:07 PM | #135 |
Rock Stacker Join Date: Jan 2017 Location: Dixie
03-21-2017, 08:26 AM | #136 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
anybody ever cut 1.9 mad beasts?
03-22-2017, 09:24 PM | #137 |
Newbie Join Date: Apr 2014 Location: 95603
What sort of pliers do you use to cut the tires?
03-22-2017, 09:52 PM | #138 |
03-23-2017, 04:13 PM | #139 |
03-23-2017, 05:48 PM | #140 |
only cut tires. post up your cut tire photos - Similar Threads | ||||
Dove cut, bobbed, cut, chopped, you name it its been threw it... California Raisin... | Madjones | Losi Micro-Rock Crawler | 6 | 11-17-2014 09:07 AM |
Post your cut tires here. | AXLE 69 | Tires and Wheels | 0 | 11-10-2013 05:12 PM |
post your cut stock tires | Steelfish | HPI Wheely King | 1 | 05-21-2013 11:22 AM |
*** proline flat irons to cut or not to cut you tell me *** | Cmace23 | Tires and Wheels | 14 | 01-21-2012 12:33 AM |
Post Pics Of Your Cut Stock Clod Tire | Xtremekrawler8 | Tires and Wheels | 5 | 05-03-2005 09:05 PM |
