Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: only cut tires. post up your cut tire photos
Old 03-28-2017, 12:07 AM   #141
Default Re: only cut tires. post up your cut tire photos
Thinned the stock tires of my maverick scout (hsp pangolin, redcat everest etc..) by removing a strip off the center.
The same happened to the stock beadlocks to make the tires fit better and get a somewhat more rounded profile.
Vagos2 is offline   Reply With Quote
Old 10-12-2017, 10:57 AM   #142
v33
shaved thread Pitbull Rock Beast XL 1.9's...
v33 is offline   Reply With Quote
Old 10-12-2017, 11:09 AM   #143
Proline boggers, cut small lugs out:
Pabust is offline   Reply With Quote
Old 01-01-2018, 09:37 PM   #144
Cut my first set of tires! Cut out some lugs from the Vaterra Twin Hammer stock tires (Race Claws). Have not had a chance to test, but will be getting some trails this upcoming weekend. usually run a set of Proline FlatIron 2.2 non XLs.
Damatheus is offline   Reply With Quote
Old 01-30-2018, 11:52 AM   #145
Tire&Foam Extraordinaire
Nova's Ark's Avatar
Wheels: 2.2 Vanquish Products
Tires: 1.9 Pro-Line TSL Bogger w/ cut lugs
Foams: Crawler Innovations Deuce's Wild part no. CWR-3005 for the inner and Double Deuce part no. CWR-1087 for the outer
How much the removed lugs weigh:
Nova's Ark is offline   Reply With Quote
Old 01-30-2018, 12:04 PM   #146
Probably the wrong spot to ask but with all these custom and insanely good looking tires, has anyone done a 6.5-6.75 tire on regular 2.2's say from a 3.8 tire?
cmbscx10 is offline   Reply With Quote
Old 01-31-2018, 08:44 AM   #147
Nova's Ark's Avatar
It's been done, but it's not the best performing. 3.8" size rc wheels and the cars that use them are heavier and the tire carcass requirements are different. In general, large scale means thicker and firmer rubber compounds. That is why so many 2.2 comp crawlers will cut n shut 1.9 tires into larger sizes. The 1.9 tire carcass is thin and more pliable. Perfect for 3-5 pound 2.2 comp crawlers.
Old 02-09-2018, 10:53 AM   #148
Did you have to remove any inner material to get the CWR-3005 to fit on a 2.2” wheel?
dpcardoza is offline   Reply With Quote
Old 02-09-2018, 11:06 AM   #149
Nova's Ark's Avatar
No.
These have no wheel weights, only the smooth vp clamp ring.
Old 02-09-2018, 11:10 AM   #150
No.
Would this work with your 2.2 wheels ya think? If so 1” or 1.5”
Old 02-09-2018, 11:22 AM   #151
Nova's Ark's Avatar
Yes, on the 1" wheels; P/N: CWR-5003; that would duplicate the look on the 1" width 2.2 VP bead locks pictured.
The 1.50" width 6 Bolt Wheel; P/N: CWR-5004, is as wide as the Pro-Line tire, and it would need P/N: CWR-3015 tuning discs on the side of the inner to add width to fill the tire laterally.
Old 02-15-2018, 07:14 AM   #152
Nova's Ark's Avatar
Vanquish Products 1.9 KMC Enduro XD222 bead lock wheel
Vanquish Products KMC Enduro 1.9 beadlock ring black anodized
RC4WD 1.9 Mickey Thompson Baja Claw TTC Tire that has been cut n shut narrowed, sanded, with cut pattern
Crawler Innovations 4.50" Lil Nova Foams P/N CWR-2025 front; CWR-2026 rear
Old 05-07-2018, 08:30 PM   #153
Here's a before & after of my stock Trx-4 tires 4.6 x 1.9 Canyon Trail. Simple cut with great results! Have a great day!
Sent from my SM-S975L using Tapatalk
AnimalHippie is offline   Reply With Quote
Old 05-16-2018, 06:23 AM   #154
Preparing the tires for my super
This is my first time I cut and shut tires so I decided to use some cheap tires I found on Alibaba that will allow me to learn how to do so and test the rig.
I am very happy with the results
Then latter will make comp ones with other kind of tires.
gonper is offline   Reply With Quote
Old 08-08-2018, 10:17 AM   #155
ussprinceton2004 is offline   Reply With Quote
Old 08-08-2018, 11:06 AM   #156
Axial 2.2 kr2 cut down to 1.9. I made my own cut about 3yrs ago. Kr2.5 bfg's decent all around tire. 4.3-4.65 tall depending on foams.
Sent from my LGMP260 using Tapatalk
CM9000 is offline   Reply With Quote
Old 10-12-2018, 12:15 PM   #157
1.9 Canyon Trail (stock Trx-4 tires) AnimalHippie cut.
Old 10-12-2018, 01:31 PM   #158
Cali Cut Treps
raul shabinguez is offline   Reply With Quote
Old 05-11-2019, 06:27 PM   #159
Attachment 331660
Attachment 331661
Attachment 331662
Attachment 331663
Rims: Crawler Innovations 6 Bolt Wheels in the 1.50" Width
Tires: CI Cut Pitbull 2.2" Growlers
Foams: CI 5.5" Double Deuce Comp Cut Inners with Medium Outers
..Uploaded from the lab @ the C.I. Compound...
Hey brother, Thinking about doing one of these cuts to my set of 1.9 4.75 growlers. Which one worked out better for you?
Old 05-22-2019, 10:04 AM   #160
I went ahead and cut my Pitbull Growlers. They turned out pretty good.
Tested them vs my Hyrax both tires did really good on the rocks. Not sure which one is better. Here's a video I shot on how to cut them and the test vs the Hyrax.
https://youtu.be/-3sc0alnZao
only cut tires. post up your cut tire photos - Similar Threads
Dove cut, bobbed, cut, chopped, you name it its been threw it... California Raisin... Madjones Losi Micro-Rock Crawler 6 11-17-2014 09:07 AM
Post your cut tires here. AXLE 69 Tires and Wheels 0 11-10-2013 05:12 PM
post your cut stock tires Steelfish HPI Wheely King 1 05-21-2013 11:22 AM
*** proline flat irons to cut or not to cut you tell me *** Cmace23 Tires and Wheels 14 01-21-2012 12:33 AM
Post Pics Of Your Cut Stock Clod Tire Xtremekrawler8 Tires and Wheels 5 05-03-2005 09:05 PM
