01-20-2015, 05:25 PM | #1 |
Pebble Pounder Join Date: Jul 2014 Location: Atlanta
| Tire grooving/ cutting
What is the best method yall have found to cut tires? I've tried body scissors and that just ain't workin. Any suggestions?
01-20-2015, 05:30 PM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
| Re: Tire grooving/ cutting |
01-20-2015, 05:34 PM | #3 | |
| Re: Tire grooving/ cutting Quote: Thanks man I'll have to get me a set! | |
01-20-2015, 05:34 PM | #4 | |
| Re: Tire grooving/ cutting Quote: Could you get something like this at Home Depot or lowes or somewhere similar? | |
01-20-2015, 05:40 PM | #5 |
01-20-2015, 05:41 PM | #6 |
01-20-2015, 05:53 PM | #7 |
Newbie Join Date: Jan 2014 Location: New London
I cut and siped my scx-10 rubican maxxis trepador tires with my demel. I just used a thin cut off wheel, worked perfect, and the best part is it smells just like the burnout box at the drag strip!
01-20-2015, 07:53 PM | #8 | |
That's a good idea too I've got my dremel sitting here now might try that too | |
01-20-2015, 09:33 PM | #9 |
Quarry Creeper Join Date: Apr 2014 Location: a land bereft of rocks
cuticle nippers work great and your girlfriend/wife/mother probably has a set laying around
08-06-2015, 05:49 AM | #10 |
Pebble Pounder Join Date: Jan 2014 Location: Rochester
I searched and found this thread and would like to revive it to ask a question. I see in 1:1 scale crawlers people use a heated blade to cut or slice into the tire tread. That is sipeing the tread for traction, so when we use a Dremel cut off wheel is that the same thing or is that grooving the tread? I think I will just have to experiment with some tires to find out if one is better than the other but if anyone else has experience with this let me know.
08-06-2015, 06:49 AM | #11 | |
I joined the Band! Join Date: Dec 2014 Location: Earth
Siping an RC tire would be cutting slices in the tread with a hobby knife or razor blade. | |
08-06-2015, 05:04 PM | #12 |
Newbie Join Date: Jul 2015 Location: LV-426 (Acheron)
+1 What Eric Said.
08-06-2015, 05:50 PM | #13 |
So using a hobby knife to cut the thin slices in the tread might help with smooth rock surfaces and wet rocks? Cutting in to the tread with the dremel might help with rougher surfaces of rock? I have Pit bull Rock Beast 2's and I was thinking about doing the thin slices in some of the bigger lugs to get more grip on the rocks. Thank you for the info. |
08-06-2015, 07:07 PM | #14 |
Newbie Join Date: Jun 2015 Location: On my workbench
Dremel tool. |
08-07-2015, 12:51 PM | #15 | |
08-07-2015, 08:07 PM | #16 |
Flush cutters or nips work great for removing lugs. When doing a groove a cut off wheel in the dremel is my go to tool. I don't think you'd really notice a difference between siped and non siped tires in an rc situation. |
08-13-2015, 09:31 AM | #17 |
Newbie Join Date: Oct 2013 Location: Apex
I like to use a pair of model sprue cutters, they were well worth the $15 or so I paid.
11-19-2015, 09:44 PM | #18 |
Pebble Pounder Join Date: Aug 2015 Location: Oklahoma
Dug thus thread up looking for what tools to cut tires with. Used some little angled wire cutters and they worked great. But... I learned the hard way that when you cut tread off, DO NOT PULL THE TREAD WHEN YOU MAKE THE CUT. Pulling the tread will pull up rubber that you don't want to cut. In my case, I made a hole in the tire. Simple fix but still annoying. What I began doing was pull the tread up, get the cutters in place, then let go of the tread and make the cut. Made a perfect cut every time. Just thought I'd give a little bit of advise to the next guy that's never cut tires. |
11-22-2015, 07:21 AM | #19 |
Newbie Join Date: Mar 2010 Location: fredericksburg
I used a pair of side cutters to cut mine
03-28-2017, 10:50 AM | #20 |
Newbie Join Date: Apr 2014 Location: 95603
I've been cutting my tires with a pair of wire snips
Tire grooving/ cutting - Similar Threads | ||||
cutting tire foam?? | 1TONCHEVY | Tires and Wheels | 12 | 12-04-2008 01:31 AM |
Grooving/Cutting tires? | kizzo | Tires and Wheels | 5 | 04-17-2008 07:07 AM |
tire cutting | badltl510 | Newbie General | 1 | 07-28-2006 09:32 PM |
Patching tire holes after grooving. | MTUJeeper | General Crawlers | 11 | 03-02-2006 06:39 PM |
