Go Back   RCCrawler Forums > RCCrawler General Tech > Tires and Wheels
Thread: New 2.2 Pitbull Rock Beast II review
Old 08-19-2012, 02:56 PM   #1
Default New 2.2 Pitbull Rock Beast II review
So I got these mounted up today and spent one hour running them on rock and dirt.
First of all I'd like to say how easy they were to mount up. The bead seems to hold real nice too. I mounted them up on my BAM 1" wide 6 spoke beadlocks. I used a pair of Crawler Innovations closed cell 5.5" inners with medium outers in front. The rear used 6.0" inners with firm outers. They fit perfectly and filled the tire like they were made for them. These tires seem to have a bit thicker sidewall than the 1.9's and with these foams the carcass flexes just the right amount, they let the tire compound do all the work. I noticed that the tread really bites into the rock and you can hear the lugs working.
I tried my usual spots at Rivervilla that I have crawled for the last 6 years. The tires performed the same or better as all the other tires I've tested down there. I drove all the spots from my tire test that I did earlier this summer and couldn't really tell the difference until I tried two lines that I haven't ever been able drive.
The first one is a rough steep climb that has ledges that aren't friendly to a 13" wheelbase rig. After one attempt where I started in the wrong spot I lined up in a different spot and with a bit of rear steer, proceeded to drive right up it! I got really excited.
This got me to thinking about a couple other lines that I've had trouble with and decided to work my way north through the park.
So the start of this climb is an off camber where you really need to get lined up for a ledge.
The you need to steer full lock to the left and hook a tire to pull your self up.
Then you have to get all the way to the right and bump it perfectly to keep from flipping back and off the ledge. I did it twice!
Played around a bit more until my battery dumped......
As you can see, they sidehill like a mother!
War Pig is offline   Reply With Quote
Old 08-19-2012, 03:19 PM   #2
Default Re: New 2.2 Pitbull Rock Beast II review
WOW! Hard to believe that that rig could look any nicer...those are killer!
They perform as well as anticipated? (I'm sure they do)
(Edit:i just noticed you actually included WORDS in your post...1st time through all i saw were the tires)
Thanks for the pics
Mr.Joshua is offline   Reply With Quote
Old 08-19-2012, 03:24 PM   #3
Cracking set of Pictures
Those tyres do look the Absolute Buisness will be on my List for deffinate
Dready is offline   Reply With Quote
Old 08-19-2012, 03:28 PM   #4
I saw these tires in action today and their performance is as impressive as their looks!! Pitbull did a really nice job with these things!
TURBOFEST is offline   Reply With Quote
Old 08-19-2012, 03:39 PM   #5
How tall where these mounted?
sally1800 is offline   Reply With Quote
Old 08-19-2012, 03:45 PM   #6
A hair over 5.75"
Old 08-19-2012, 06:26 PM   #7
dezmoon's Avatar
I as well was able to Mount My Rock Beast II's up and get em out on some Rocks and into some slop,, I have mine mounted on some 1.25 wide wheels from Motoworks,,love the wheel,,just not for this tire,,I have no weights in the wheels becauseTHIS IS NOT MY FINAL SET UP ( waiting on my new wheels ) I have em filled with CI closed cell 2 stage foams 6.0 frt and rr soft up front and med out back,,and no Vents (yet ,,I may in the future ) and like Tim I felt like the foams were perfect.. To be honest Today was not even a fair test for what the True Capabilities of this tire,,the spot I went to Is one of our clubs Toughest spots for our comp series and any one who has ever comped there would back me up,,
Right out of the box you can feel the difference between these and the other 2 Tires From Pit Bull,,The side walls Integrity is a Gigantic leap forward which is Awesome,,Like Tim, I had no Issues mounting these ..onto the Pics
comparison shot with the few that I own..
Like I said this place is Tough and these Tires, on a rig that really wasnt ready for the Flogging it Took Today,,Really Out Performed any,or all of m
My expectations I had,,After My First Pack I called THE PIT BULL himself to express My Gratitude,,These Tires Pulled lines that Ive done with my 2.2 comp Rig,,It made me Giggle a bunch outloud....
dezmoon is offline   Reply With Quote
Old 08-19-2012, 06:33 PM   #8
Those look great, glad to hear they work well aso
jmz6 is offline   Reply With Quote
Old 08-19-2012, 06:43 PM   #9
TLTCrawlin's Avatar
Sweet tires and rig...... Is that mad force axles?
TLTCrawlin is offline   Reply With Quote
Old 08-19-2012, 06:52 PM   #10
dezmoon's Avatar
of course I tried a Bunch of lines Ive done before with My Comp rigs,,some with failure,,But a Bunch with Success, Over all It was A Great Day,and a Great Beginning to Awesome Tests to Come,,
Old 08-19-2012, 06:59 PM   #11
these will probably be my next tire purchase,
how do they handle the mud?
gabehunt is offline   Reply With Quote
Old 08-19-2012, 06:59 PM   #12
dezmoon's Avatar
Thanks John,,,Pit Bull Killed It with This One,,I was Stoked with the 1.9..But These,,Good God..
Thanks Man,,Yeah they are the 1st set (I Think) of 2.2 sized Mad/Twin Force Axles YOTACHUMP made Years ago,,Ive Been Running them for a few Years Now,,Love em,,and the Tires Give em The Clearance they have been needing,,
Old 08-19-2012, 07:02 PM   #13
dezmoon's Avatar
The Slop I ran them In Today was a walk in the Park,,,They Clean Out Fast,,a couple of blips and there cleaned out...
Old 08-19-2012, 07:02 PM   #14
TLTCrawlin's Avatar
About same width was wraith I take it?
I'm lookin at doing a wraith axle TTC rig, and want big tires (like this) if I go 1.9 I'm going SCX axles.
Old 08-19-2012, 07:13 PM   #15
dezmoon's Avatar
Not sure width between wraith axles and the M/f axles,,the Wraith axles have Tons more Steering and Better Clearance I know That,,Either way you Go 1.9 or 2.2,,Pit Bull has You Covered...
Old 08-19-2012, 07:47 PM   #16
hey Tim do you know when they will be released and a price im itchin lol
EvanSouders is offline   Reply With Quote
Old 08-19-2012, 08:03 PM   #17
I heard mid September, don't know about price.
Old 08-19-2012, 08:44 PM   #18
dezmoon's Avatar
mid to End September,, and Rumor has it at about $29.99 a pair,,again thats Rumor
Old 08-19-2012, 08:57 PM   #19
MMmmmm they look yummy I cannot wait!
Hittman is offline   Reply With Quote
Old 08-19-2012, 09:16 PM   #20
These look great...looking forward to getting a set of these to check out!
ittybitty is offline   Reply With Quote
New 2.2 Pitbull Rock Beast II review - Similar Threads
1.9 Pitbull Rock Beast FuzzyCrawler Tires and Wheels 6 03-19-2012 06:37 PM
