02-02-2022, 01:14 PM | #1 |
Rock Crawler Join Date: Nov 2014 Location: North to Alaska - go north, the rush is on....
| Single Stage Waterproof Foams for 3.85” 1.55’s
As the title states, it’s am looking for some Single Stage Waterproof Foams for 3.85” 1.55’s and looking for some recommendations for a rig in the 10 lb range. The tires are Proline Swampers in Predator compound and I will likely vent the tires. The foams that came with them is way too soft. It looks like I have 4 flat tires… I was considering the pool noodle idea, it’s just the wrong time of year to find that stuff up here lol TIA Last edited by AK KRAWLER; 02-02-2022 at 01:28 PM. |
02-02-2022, 01:38 PM | #2 |
Quarry Creeper Join Date: Nov 2020 Location: Greece
| Re: Single Stage Waterproof Foams for 3.85” 1.55’s
I had good luck with Deuce Wilds Heavy duty foams by Crawler Innovations, for my Defender. Almost a year in service now and still holding strong. https://crawlerinnovations.com/deuces-wild/1-55/ |
02-02-2022, 02:24 PM | #3 | |
| Re: Single Stage Waterproof Foams for 3.85” 1.55’s Quote:
https://crawlerinnovations.com/deuce...l-foam-pair-2/ Last edited by AK KRAWLER; 02-02-2022 at 02:37 PM. | |
02-04-2022, 08:52 PM | #4 |
This might be another option, but I wish they listed a weight range the would support. I guess if they were too soft, I could fill some of the pattern up to achieve my goals. https://www.boomracingrc.com/rock-mo...4-green-191690 CI still has not gotten back to me with the questions I sent them from their "Contact Us" section of their website *EDIT** The Boom Racing inserts might be a bit too skinny... This is an offering from Crazy Crawler https://www.crazy-crawler.de/LaserFo...uct-20-29.html Last edited by AK KRAWLER; 02-04-2022 at 09:05 PM. |
02-08-2022, 02:52 PM | #5 |
Well, I decided on the offerings from Creepy Crawler. They were a little taller that the C.I. option that I could find. Once they arrive and are installed, I will report back to this thread, as well as, I will update my main thread in the Redcat Section. |
05-01-2022, 03:01 PM | #6 |
Newbie Join Date: Dec 2018 Location: Canada
| Re: Single Stage Waterproof Foams for 3.85” 1.55’s Any update on this?
05-01-2022, 03:27 PM | #7 |
| Re: Single Stage Waterproof Foams for 3.85” 1.55’s Actually yes, thanks for poking the bear, as I need it sometimes. They were a little wide for the tires, so I shaved them down a little and they fit perfect, as well as stopped the tires from smashing down so far. Now that summer is here again, I need to put these back on and try them outside a bit. There are some pictures here New Gen8 AXE Edition. Choices, choices, choices... Unfortunately, the Redcat Gen8 portal axles are just too wide to get a decent scale look out of this truck body. I will likely end up using these on a different build down the road, as I do want to build something a bit more scale’ish. I’ve got the suspension lowered as much as possible and the body is as low as I can get it without major modifications, but that does not fix the axle width issue. Last edited by AK KRAWLER; 05-01-2022 at 03:47 PM. |
Single Stage Waterproof Foams for 3.85” 1.55’s - Similar Threads | ||||
Single stage foams question | Jboucher | Tires and Wheels | 6 | 12-03-2017 11:46 AM |
1.9 Single Stage Open Cell Foams | JatoTheRipper | Tires and Wheels | 9 | 03-15-2016 06:49 AM |
CI single stage 2.2 tall foams | tacocat | Tires and Wheels | 2 | 01-27-2015 08:35 PM |
--- C.I.'s Single Stage Double Deuce Foams --- | Nova's Ark | Crawler Innovations | 7 | 03-01-2012 10:32 AM |
