Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Band saw suggestions....
Old 02-28-2010, 02:28 AM   #41
Originally Posted by Joat View Post
Not even close , scrolls saw are good for intricate work and inside cutting,even then they can not cut quickly or where designed for metal working the blade retention can not handle agressive work.
http://www.amazon.com/Proxxon-37172-.../dp/B001D6PJAQ offers free super saving shipping, theres these 2 also put you need to pay for shipping
http://www.amazon.com/gp/offer-listi...condition=used
http://www.amazon.com/gp/offer-listi...on=refurbished
And if your dimeing it the first one is 260 but you need to pay for shipping of 12.89 which says you $6
http://www.amazon.com/gp/offer-listi...&condition=new
so I was thinking that band saw would be better for doing contour or round cuts versus a scroll saw...., correct?
5150bronco is offline   Reply With Quote
Old 02-28-2010, 04:15 AM   #42
really depends on blade width and how tight of a radius, a narrower blade can do tighter work, but I dont think they make a really narrow bimetal blade ?the narrowest I found was 1/4" and even proxxon only offers a bimetal at 6mm but that's a 10/14 varitooth, probandsaw offers a 14/18 which is better.
I havent tried to see what is the smallest radius I can cut,I know I can do a 2" circle, but scrolls can do the width of a blade
Joat is offline   Reply With Quote
Old 02-28-2010, 07:05 AM   #43
I agree with joat it in what you need
rocket man is offline   Reply With Quote
Old 03-01-2010, 03:04 PM   #44
well, building scaler so not too tight, but I would think there are going to be tight cuts if you wanted to make something scale.......any thoughts?
Old 03-01-2010, 04:24 PM   #45
I think you should be fine, you may need to do some hand clean up, but should be able to do fine with a bandsaw for the most part, scroll saws are just not designed for agressive work
Old 03-02-2010, 01:33 AM   #46
okay. that is good to know. I was starting to think about the width of the blade and thinkin band saw might not work. I guess i am going to pull the trigger on one on craigslist.
Old 03-03-2010, 01:44 AM   #47
buying the band saw tomorrow. cant find metal cutting blades for the scroll saw anywhere. Works great on the Delrin and wood, but im sure it sucks on metal.
savagefromthesprings is offline   Reply With Quote
Old 03-03-2010, 10:40 PM   #48
band saw is so easy to use and very smooth. highly recommended!
Old 03-04-2010, 01:44 AM   #49
you guys think this will work out fine?
ryobi from depot?
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old 03-04-2010, 06:51 AM   #50
With my experience with Ryobi stuff, I wouldn't trust it to cut a straight line to save my life. I'm planning on holding out/saving up for one of those Proxxon saws. I just need more room in my garage first!!
Tommy R is offline   Reply With Quote
Old 03-04-2010, 07:32 AM   #51
Suck it up!
Duuuuuuuude's Avatar
ryobi from depot?
Do it!
Duuuuuuuude is offline   Reply With Quote
Old 03-05-2010, 02:29 AM   #52
Originally Posted by Duuuuuuuude View Post
Do it!
have you had any experience with them or this one?
Old 03-05-2010, 07:06 AM   #53
Suck it up!
I was looking at the Ryobi before I bought the Skill. Both were about the same price, but I have a thing against HD so I bought at Lowes.
Old 03-05-2010, 07:13 AM   #54
So the Skil cuts metal straight? Any idea how thick it can cut metal materials? Thanks!
Old 03-05-2010, 08:02 AM   #55
i cut 1/4 aluminum with mine. just takes time and some burnt fingers
i would stay away from trying to cut any steel, i could see that taking forever.
TANK is offline   Reply With Quote
Old 03-05-2010, 09:12 AM   #56
Also if your military or prior military you get a discount at any Lowes store in the country. You just have to remember to ask for it. It's like 15 or 20% off. If your not military just find an old salt dog that would be willing to buy it for you.
newtocrawling is offline   Reply With Quote
Old 03-05-2010, 09:18 AM   #57
I've gotten up to only about 3/8" but eat up 3 blades cutting 10 inches. If I heat the metal prior to cutting and cut while it's still warm it's alot easier.
Old 03-05-2010, 09:36 AM   #58
Hmm... That's my concern. I would imagine it would cut 16 gauge sheet steel reasonably well and that'd be great for the bulk of my RC projects, but I'd like it to handle the occasional 1:1 project, too, and that would require cutting 1/4" steel usually.
Were you cutting dry or did you use any wax or cutting fluid?
Old 03-05-2010, 09:43 AM   #59
1/4" you'll be fine with. I don't use any wax or cutting fluid. Like I said I found if I heat the metal with a propane torch then cut on it it works just fine, and goes a little quicker. I guess I could try some cutting fluid this weekend on one of my projects and let you know if it's any better.
Old 03-05-2010, 10:26 AM   #60
Thanks! I appreciate the info...
I've been searching local ads and was wondering if anyone is familiar with Jet or Kity brand band saws? They appear to sell for some pretty decent money so I am assuming they may be high end, but I've never heard of either. I'm mainly concerned about parts/blade availability. The ones I'm looking at are 12" and 14".
Thanks,
Tommy
