Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Brazing sold rod
Old 12-14-2011, 06:25 PM   #1
Default Brazing sold rod
Any tips on how to braze solid rod as opposed to brake line.
I will be working with 1/4" amd 5/16" solid cold rolled rod.
fbuonpensiero is offline   Reply With Quote
Old 12-14-2011, 06:50 PM   #2
Default Re: Brazing sold rod
No different just takes a bit more to heat up.
Erin is offline   Reply With Quote
Old 12-14-2011, 06:55 PM   #3
Yeah same as tubing.. Just need more heat or hold it there alot longer.. A good map gas tip will do well if you don't have oxy/ace tanks.. The more precise the tip is the quicker it'll heat and make sure you heat both pieces evenly
J-bird
j-bird is offline   Reply With Quote
Old 12-15-2011, 11:25 AM   #4
Any good YouTube videos you recommend?
Maddog Madigan is offline   Reply With Quote
Old 12-15-2011, 11:30 AM   #5
The process is the same as any other brazing. If you are brazing any tube to solid rod watch where your tip is and how hot each piece gets. Solid rod takes longer to heat but its not bad. Take your time and practice on scrap to get your timing and get to know what your material looks like when it reaches the right temp. The videos got me started but it cant compare to hands on and seeing it first hand. Practice practice. Its worth it.
Propane is offline   Reply With Quote
Old 12-15-2011, 12:46 PM   #6
There is a Sticky at the top of this section on brazing.
profsrkos2012 is offline   Reply With Quote
Old 12-15-2011, 04:58 PM   #7
J-bird
sorry man but there is no damn way a Mapp cylinder is going to get the solid rod hot enough to get a good braze joint, it's gonna take oxy/acetylene with a small tip, flux and some bronze filler rod to make a nice solid joint. There's a reason the Harris silver rod is called 'silver solder', it's because it's only making a solder joint, not a braze joint.
BigSki is offline   Reply With Quote
Old 12-15-2011, 07:21 PM   #8
Yep
Hacksaw707 is offline   Reply With Quote
Old 12-16-2011, 08:36 AM   #9
While I agree, I've built a bunch of stuff out of solid brass rod using cheap solder and propane, and those joints have held up very well for the most part. But that's brass.
92PathSE is offline   Reply With Quote
Old 12-16-2011, 10:40 AM   #10
MAPP can do the job very well.
Heat the rods that need to be joined until red hot, then test the spot by touching the brazing rod to see that it melts and flows smoothly. Make the solid rods hot enough so when you touch the brazing rod to them, they melt the brazing rods. Practice makes perfect.
RusT808 is offline   Reply With Quote
Old 12-27-2011, 04:20 PM   #11
REST IN ALOHA CHIP
YoUnG_vErSiOn's Avatar
i ususally tack it in place with my mig, then follow up with my turbo torch,sine the mig welds don't melt, the braze flow right into them. I'm looking into getting a remote setup with a larger mapp gas tank.
YoUnG_vErSiOn is offline   Reply With Quote
Old 12-27-2011, 08:42 PM   #12
Never had trouble w mapp/solid rod. Beat the piss out of my front bumper on Parkers courses for 3hrs. Bent the rod but all joints held strong.
Old 12-28-2011, 01:40 PM   #13
The brazing vid in the sticky doesnt work. Its just an image now. I just tried it. Just thought you guys should know.
Terra Rover is offline   Reply With Quote
Brazing sold rod - Similar Threads
brazing 1/8 rod gary Tools, and Procedures 2 09-27-2010 08:19 PM
brazing 1/8 rod gary Newbie General 2 09-27-2010 01:08 PM
question on brazing rod and a few others lostissues Tools, and Procedures 14 12-17-2008 06:10 PM
What Brazing Rod Mike-63 Tools, and Procedures 4 11-04-2007 04:53 PM
brazing solid rod? swamp_rat Tools, and Procedures 3 03-16-2007 07:37 PM
