04-01-2012, 12:08 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: 419 area
| stripped set screw
the set screw in my pinion is stripped so how do i get it out with out hurting the pinion? i was going to use a dremel with a cut off wheel and slot it so a flat head screw driver will fit but i dont want to hurt the pinion. any suggestions.
04-01-2012, 12:23 AM | #2 |
I joined the Band! Join Date: Feb 2012 Location: bay area
| Re: stripped set screw
Put some heat on it with a cigarette lighter then use an ez out.
04-01-2012, 01:41 AM | #3 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
Or just do what you were going to do....a new pinion is what, 2$ right? You'll spend more on ez out then a new pinion......
04-01-2012, 07:05 AM | #4 |
RCC Addict Join Date: May 2010 Location: Midwest
You could try to see if a Torx bit will fit in there and bite something? I've done that before and it worked.
04-01-2012, 07:29 AM | #5 |
Quarry Creeper Join Date: Jan 2011 Location: Perth, Western Australia, 6108
I drilled one out of a drive shaft on my Honcho. If the pinion is hardened it might be safe to try.
04-01-2012, 03:44 PM | #6 |
Also left hand bits can work. I keep a few 1/16th", 1/8th" & 1/4" bits. Just as they grab a chip, they may drive the broken part out. I get mine from McMaster Carr. |
stripped set screw - Similar Threads | ||||
Set screw stripped | RCTRUX | Axial SCX-10 | 12 | 04-28-2011 08:57 PM |
How do i remove a stripped set screw?!! | ser3100 | Tools, and Procedures | 12 | 01-02-2010 09:12 PM |
Stripped set-screw | Brandon13 | Newbie General | 17 | 01-25-2009 05:46 PM |
stripped set screw fix | solomon7 | General Crawlers | 6 | 06-23-2008 10:11 PM |
