08-17-2012, 05:43 AM | #41 |
Rock Stacker Join Date: Nov 2009 Location: hamilton, oh
| Re: A tube bender on the cheap
nice
08-23-2012, 09:54 AM | #42 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
I couldn't find the strainer plate, but did find this at my favorite store (Princess Auto) It is a plate for a meat grinder and was only $3 then picked up some 3/8 flange bolts and nuts the hole thing cost about $4.50 Sent from my GT-I9100M using Tapatalk 2 |
08-23-2012, 10:08 AM | #43 |
RCC Addict Join Date: Jan 2011 Location: Wheat Ridge
| Re: A tube bender on the cheap Right on, I like this plate alot, good find eliminates the possiblity of cracking or shattering like the cast iron plates, plus you can draw you anlges on it |
08-23-2012, 11:06 AM | #44 | |
Sent from my GT-I9100M using Tapatalk 2 | |
08-26-2012, 07:51 PM | #45 |
Rock Crawler Join Date: Oct 2011 Location: Corona, CA
Not to take away from the Hawai'ian thinkin', but Harbor Fright has a little hand bender. I've only used it for testing if I could bend 1/4" solid round for a project a few years ago, but will also do 3/16" solid round, which I am working on now for links and link brackets (stay tuned in my build thread ;) ) Tubing Bender - Save on this Manual Tubing Bender However, you are stuck with the radius being what it is. With the drain plate version, you can use the radius off the bolt, or stack larger washers to get a bigger radius |
08-26-2012, 11:06 PM | #46 | |
like I said I have a bender similar to the one you posted a link to, and yet I made this and find I goto it the most. being a heavy duty mechanic I have a large tool box full of tools. You would be surprised at how many different tools in that box that can do the same job. just in a different way. some easier and some faster, but all equally important to the user. most of my most used tools at work are home made or modified. Sent from my GT-I9100M | |
10-08-2012, 06:40 AM | #47 |
Newbie Join Date: May 2012 Location: south of chicago
Gonna have to try that out.
10-19-2013, 11:11 AM | #48 | |
Newbie Join Date: Oct 2013 Location: Manitowoc
| Re: A tube bender on the cheap Quote:
A tube bender on the cheap - Similar Threads | ||||
Tube bender | GREEDY GENIUS | Tools, and Procedures | 6 | 06-23-2011 05:24 PM |
tube bender | timmy85 | Tools, and Procedures | 17 | 02-20-2010 04:58 PM |
which tube bender? | psun786 | Tools, and Procedures | 1 | 07-27-2008 10:32 PM |
Tube Bender?? | 90DEGREES | Chit Chat | 1 | 02-17-2006 01:57 PM |
