07-06-2012, 01:50 PM | #41 |
| Re: 15* endmill/custom ground milling tools
If you go to mylittlemachineshop.com, they give step by step instructions on shaping HSS to make your own cutters. It aimed at the guys who have bench top lathes and mills but the lessons (and the tool steel) work for everything.
07-06-2012, 02:09 PM | #42 |
Is this metal, plastic, or wood you are forming? Pics of your tool holders could help too.
07-06-2012, 02:21 PM | #43 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
If the material you are cutting is pretty soft you can get HSS blanks and grind them down. They come in different sizes, and you grind in the shape you want. I would recommend buying american made HSS blanks, it is far more durable. It takes a little while to get used to it, I'm not all that great at it, but I've done it once with pretty good results. Just take your time, make sure you leave room to clear everything. |
07-06-2012, 04:22 PM | #44 |
some times i wonder if any of you guys read at all or just look at the pretty pictures |
07-06-2012, 06:18 PM | #45 |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
| Re: 15* endmill/custom ground milling tools Telling you what tool you need for details that are not shown is difficult. the material we are cutting is a important detail, and the specificic shape is also important, I have 4 feet thick of catalogs just to select specific tools to make a cut. just saying, Last edited by tom@vp; 07-06-2012 at 06:23 PM. |
07-07-2012, 09:49 PM | #46 | |
Quarry Creeper Join Date: Jun 2007 Location: Sandy,Oregon
| Re: 15* endmill/custom ground milling tools Quote:
I could grind you a piece of HSS tool steel to cut face grooves into aluminum. Very easy to do. I have narrowed and regrooved dozens of beadlock wheels for guys in our local club. I'll be going into the shop tomorrow, I will try to remember to grind something up for you. | |
07-12-2012, 12:14 PM | #47 |
ill be damned im sorry guys, i posted this on a couple other forums and posted the material. not sure how it got left out here. sorry about that fellas. its 6061 aluminum. you guys have been more helpful than anyone. groove is .11" wide and .2" deep. OD is 2.07" ID is 1.85" Last edited by STANG KILLA SS; 07-12-2012 at 12:28 PM. |
07-12-2012, 07:22 PM | #48 |
This will do the trick for you, ground up a piece of highspeed steel and did a test cut in a piece of 6061. Groove width came out at .115 wide so I did a little touch up and should cut right on .11 I made the groove well over .2 deep. Need to have flood coolant and clear chips a couple times. I wouldn't plunge it in one cut. |
07-13-2012, 08:04 AM | #49 |
sick! thats awesome bro! thanks! is this done by hand? or CNC? how do you keep the sides straight if done by hand? or is that not important? <---trying to learn as much as i can |
07-13-2012, 08:06 AM | #50 |
Looks ground by hand to me.
07-13-2012, 12:24 PM | #51 |
Yeah I would say hand ground. Stang, it takes time and and a lot of screwing up until it is correct. We use radius gages and squares to check ours. I suck profoundly at off hand grinding but we have some guys that can grind them so well that look like they came off a edm. Sent from my Galaxy Nexus using Tapatalk 2 |
07-13-2012, 04:45 PM | #52 |
| Re: 15* endmill/custom ground milling tools start on page 18, it's a very easy to follow guide on shaping your own cutters. It's not as scary as it seems. |
07-13-2012, 04:45 PM | #53 |
| Re: 15* endmill/custom ground milling tools http://littlemachineshop.com/Info/Mi...UsersGuide.pdf start on page 18, it's a very easy to follow guide on shaping your own cutters. It's not as scary as it seems. |
07-13-2012, 09:48 PM | #54 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
Just saw this Cory. If you still need any info, I will bein the shop tomorrow morning fooling around and can take pics or talk you through any thing you need to know. It was clear to me from the very first photo what you are making. 4vryng made exactly what you are needing. That is what I use for all my wheels I narrow when regrooving them. Very easy to hand grind and all you need is a bench top dual wheel 6" grinder. A fine stone and a coarse stone. Pm me if you need anything or ever have any questions like this again. Clay Carter Fab & Machine |
15* endmill/custom ground milling tools - Similar Threads | ||||
Custom Ground carbide inserts | losikid | Tools, and Procedures | 7 | 08-31-2011 02:34 AM |
Custom tubing fabrication materials tools and procedures | Tatau | Newbie General | 2 | 06-16-2009 01:22 PM |
milling, fly cutter tools? | brendan h | Tools, and Procedures | 15 | 12-19-2008 06:24 AM |
Tools Give Away: Jp Custom Rc's | run2jeepn | Paint and Body | 120 | 05-14-2007 05:31 PM |
