12-21-2016, 11:06 PM | #801 |
| Re: Eyeball Engineering
Spindle speed and control has always been the most frustrating thing with this thing. When it bogs down for whatever reason it's almost always a cascade into a complete stall and tool breakage and/or missed steps. Unless I spend a bunch of $$$ on a bigger and better spindle and controller, I'm just going to have to live with it. Or I could do like this guy. RC parts ftw! |
12-22-2016, 06:30 AM | #802 | |
| Re: Eyeball Engineering Quote:
Thats one thing that made me happy with going the brushless route. I know couple other people who have the DC motors and have replaced the brushes and motors a few times already. But for 30$ a pop on ebay they say its worth it. I smoked the threads on my original spindle a few months back (over tightening the collet) and switched to the spare 220v 800w one I had. The original one was just a 110v 800w, both spun 24000 but the original was powered off an inverter in the control box. After switching over I could hear the difference, so much smoother spin up and a nice humm from the 220v one with its own vfd inverter. Plus now I can control the hz/rpm much better which helped get a good feel for my speeds. My only problem now is keeping controller boards from smoking. Thinking I got to much cf dust in the last case and shorted it out the other night, lost my Z control. But thats my next upgrade - encased case with better controllers. | |
12-22-2016, 07:57 AM | #803 |
In regards to cutting/ feed speeds, the Mazak taught me the importance of surface speed (lathe) and tool tip speed (mill, drill ) combined with depth of cut per rev. Using those as a start point will (almost) always yield the same results on the same setup. Between machines or brand/shape of tools, rigidity and coolant will change what is appropriate.
12-22-2016, 10:11 AM | #804 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
| Re: Eyeball Engineering |
12-22-2016, 01:00 PM | #805 |
| Re: Eyeball Engineering He said he got it all from hobby king. A quick breeze through showed a 600 series heli motor and esc for under $100. Esc controller was another $40ish. Forgot to look for a 6s battery, but I'd guesstimate that at around $50-60.
12-22-2016, 01:35 PM | #806 |
Add in the cost to make bracketry and quality power supply, and it evens back out. The larger size of standard systems give them more robustness against overheating , and they are sealed better against contamination. I didn't mount an outrunner on my taig because of the cost of good power supply. Running off a battery just doesn't work for me.
12-22-2016, 02:13 PM | #807 |
24V power supplies that can handle the amount of current needed (100A+?) for this motor aren't cheap. I wouldn't be able to deal with the annoyance of a battery to power my spindle.
12-22-2016, 02:50 PM | #808 |
I don't like wearing out just the tips of my endmills, so I run full depth whenever possible and adjust accordingly. I also use stub length endmills as much as I can. Shanks are much stiffer than flutes. |
12-22-2016, 03:49 PM | #809 |
.005" depth on a 1/16" bit is practically full depth cuts |
12-22-2016, 04:40 PM | #810 |
12-22-2016, 04:48 PM | #811 |
| Re: Eyeball Engineering I was just gonna grab the ol' deep cycles off of my fishin' boat, but you do what you want. |
12-22-2016, 05:05 PM | #812 | |
Rock Crawler Join Date: Nov 2014 Location: Dells
Series/parallel up a couple server power supplies. Not exactly UL approved, but it works. I would bet you could make a 24v 100+A for ~$150. Just remember to isolate them from each other. Exhibit A https://www.maxamps.com/24v-maxamps-...pply-47a-1150w | |
12-22-2016, 05:20 PM | #813 |
01-02-2017, 12:54 PM | #814 |
Hey Duuuuuuuude, is that steel you're machining? Why yes, that is steel that I'm machining. But at .001" doc@20ipm, I'm not going to be machining much of it. |
01-02-2017, 01:07 PM | #815 |
I wish that was a more feasible option.. I would love to be able to make my own tabs and stuff for home
01-02-2017, 01:15 PM | #816 |
I'm thinking it might do better with a smaller endmill. 1/8" through anything other than plastic or wood really works it pretty hard. I'll probably try that soon. Like you, it would be a big advantage if I could cut small steel parts.
01-02-2017, 01:38 PM | #817 |
That would be awesome
01-02-2017, 01:48 PM | #818 |
Just ran another part with the 1/16 endmill. .002"doc and started the feed at 25 ipm and slowly ramped it up. Finished the part running 42 ipm with no issues. Easy peasy. It took 5 minutes to run the single part. I can live with that. Last edited by Duuuuuuuude; 01-02-2017 at 01:50 PM. |
01-02-2017, 01:50 PM | #819 |
That's not horrible for personal use...
01-02-2017, 01:55 PM | #820 |
Certainly not production worthy, but for little bits and whatnot for a build? Hell yeah. I doubt you could hand form them as quickly and consistently. This changes things. I'm excited. |
Eyeball Engineering - Similar Threads | ||||
rocksmith engineering | D-Ride | Newbie General | 14 | 05-19-2012 11:40 PM |
Engineering Question | BJoe | Chit Chat | 14 | 03-04-2008 01:15 PM |
