06-20-2019, 01:47 AM | #481 | |
Quarry Creeper Join Date: May 2017 Location: Devon
| Re: Shop Holmes Quote:
I see 3 wires, does that mean it's sensored!? Sent from my Pixel 3 using Tapatalk | |
06-20-2019, 03:45 AM | #482 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
| Re: Shop Holmes |
06-20-2019, 06:00 AM | #483 |
Quarry Creeper Join Date: Mar 2019 Location: Low CG
| Re: Shop Holmes
I saw that it said "540-S" and had three wires, so I thought there might be a sensor port hiding somewhere on the backside out of sight.
06-20-2019, 08:17 AM | #484 |
| Re: Shop Holmes
Are these shorter Revolvers quieter? In theory they should be because there's less can to amplify the sound, right?
06-20-2019, 10:13 AM | #485 |
| Re: Shop Holmes
Thanks! These will be sensorless, but im going to attempt sensored housing design again in 3ish months. I know the hurdles, but maybe it will work better with some fresh angles of attack.
07-18-2019, 02:07 PM | #486 |
| Re: Shop Holmes
Been fiddling with the dyno today. stock axial wraith 1.9 ESC vs BRXL. BRXL allows higher peak torque, has higher peak rpm, and makes more power on a trailmaster sport 540 27t. I think the differences would be even more evident as the motors get nicer. 15% boost of peak torque, I would consider that substantial! |
07-18-2019, 03:44 PM | #487 |
| Re: Shop Holmes
One more for today. Stock 35t motor vs TrailMaster Sport 35t 540. This dyno isn't very fast switching motors out, but once I got into a groove it doesn't take too long. The stall torque increase is from better materials. The higher power is due to higher efficiency , which is from better materials Last edited by JohnRobHolmes; 07-19-2019 at 04:36 PM. |
07-19-2019, 02:36 AM | #488 | |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
Sent from my LG-H870DS using Tapatalk | |
07-19-2019, 09:10 AM | #489 |
| Re: Shop Holmes
Seeing proof of performance increases like this for certain ESCs and motors is something that should be advertised more... I'd recommend dyno charts on the Holmes Hobbes website! |
08-26-2019, 06:01 AM | #490 |
Newbie Join Date: Jul 2019 Location: Baltimore
| Re: Shop Holmes
John, i purchased the Puller Pro BL 540 XL 2100kv, what ESC's can i and should i pair this with? |
09-09-2019, 09:39 AM | #491 |
| Re: Shop Holmes
Well, my first CNC setup lasted 7 years, not too bad of a run. I started having issues with the controller, and since it is bipolar there isn't really a lot I can do to replace discrete components without scrapping the whole system. The old computer with printer port is still rocking though. That is a testimate to how stable a computer is when it is not hooked to the internet and doesn't receive constant software updates. So I've been hankering for another CNC. I really miss the big lathe, and have just been using the mill in manual mode. I would like to re-outfit the mill, but a router would do most of the work I need. For the price of re-equipping the Taig, I can get a complete router with more working space too. The hobby CNC market has come a long way thanks in part to 3d printers. But first, I need an updated CAM solution for my updated Solidworks. HSMworks is still a free 2.5d machining software and will do for my needs of integration into Solidworks 2016. https://www.autodesk.com/campaigns/hsmxpress-download And now, for the router. I think a Fortis is not a bad choice but I will do a little more research. Only 50mm of Z but I still have the mill if Z height is needed more than table size. https://folgertech.com/products/folg...tis-hd-cnc-kit. The more I think about it, the more I want to have a router and a CNC mill, lol! Thats all for today. Time to do a little CAD on some new upcoming products. |
09-09-2019, 09:40 AM | #492 |
| Re: Shop Holmes |
Shop Holmes - Similar Threads | ||||
Where to shop???????? | KNIFE | Newbie General | 21 | 08-11-2010 02:08 PM |
Who wants a shop near Kc | blazin396 | Missouri | 6 | 07-23-2010 11:47 AM |
Where to shop | Jigsisme | Losi Mini-Rock Crawler | 10 | 09-03-2009 11:02 AM |
who knows this Shop | ecodriver | Tamiya Clod Buster | 0 | 01-03-2008 12:49 PM |
