01-07-2013, 01:50 PM | #1 |
Pebble Pounder Join Date: Dec 2011 Location: riding the rails
| link bending question
for example, if i put a single 30 degree bend in a 4 inch piece of rod how much overall length would i lose end to end?
01-07-2013, 02:50 PM | #2 |
Rock Stacker Join Date: Aug 2012 Location: Schenectady
| Re: link bending question
I know this isnt a direct answer to your question but i always mock my links on a piece of cardboard. I always go eye to eye and measure the length of the 2 straight portions of the arm from one eye to the bend and the bend to the other eye. Its stupid kid math but once you add the 2 lengths together and subtract the portion that accounts for your rod ends you'll have the right material lenth. Then i cut it about 1/10th of an inch longer and grind the ends down a bit if its too long. Hope this helps
01-07-2013, 03:36 PM | #3 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
Not as much as you think. Roughly 1/8 depending on materiel. I wouldn't go about it this way though. As mentioned above mocking up the links beforehand is the way to go. If you can't do that, then I would leave some length on the long end that can be trimmed down later. I use all-thread or old links to mock them up then go from there.
01-07-2013, 07:52 PM | #4 |
thanks for the input, i guess mock up with cheap metal is the best way to go. i have plenty of all thread laying around.
01-10-2013, 03:39 AM | #5 |
Rock Crawler Join Date: Oct 2011 Location: Canada
I use metal coathangers. I can push them to the iside the traxxas rod ends that I use, and it gives me an exact length for the all thread link, accounting for the "screw-in" of the rod end.
01-10-2013, 06:06 AM | #6 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
No more wire hangers!!! Okay most people on here probably won't get that. The hanger idea is a good one, might have to borrow it..
01-10-2013, 09:31 AM | #7 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
i mock up with simple tie wire, mechanics wire, baling wire, whatever you wanna call it. and if its a single simple bend straighten it back out to get a measurement, or if its a compound bend just use it as a guide. works pretty well.
link bending question - Similar Threads | ||||
link question | slashinbashin | Axial XR10 | 2 | 02-25-2012 10:14 PM |
3 Link Question. | eemmaaxxxx | Axial AX-10 Scorpion | 6 | 01-01-2011 02:07 PM |
3 Link 4 Link length question | squad2man | HPI Wheely King | 4 | 03-05-2010 07:56 AM |
delrin links, question about bending them... | dieselfuel | General Crawlers | 6 | 01-08-2009 07:20 PM |
