12-12-2013, 09:21 PM | #61 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| Re: SMW Shop / My NEW Hobby
Love it! I'm just starting to get into using HSM toolpaths in Mastercam X7. I bet they're a huge advantage on a hobby level machine |
12-13-2013, 08:51 PM | #62 | |
| Re: SMW Shop / My NEW Hobby Quote:
12-14-2013, 05:19 PM | #63 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
Just learning the software or 10 years in its always a struggle to keep all the references happy. You will learn what methods are bulletproofish and what to never ever do again.
12-15-2013, 12:52 AM | #64 |
Kinda sucks having to do your day job for your hobby Starting with the cross slide ball nut (X AXIS). Wanted a 5/8" but only the room for a 3/8" without an extreme chopping of the cast iron. Another must have on this machine is pre-loaded balls nuts. While Mach3 will electronically account for backlash the goal here is to just mechanically eliminate it. Seems to me that any diametrical positioning error in the cutting tool will result in twice the actual error so this should help minimize it. The design is based/expanded upon pictures posted in a thread on CNCZONE, a website I highly recommend checking out. Won't get deep into the design but it should allow the balls in the two nuts to ride on opposite sides of the screws ball track. The tension will also be applied and adjustable using the wavy springs and adjustment collar. The green shoulder bolt will be custom as well to lock down the ball race yet still allow the brackets/nuts to float relative to each other axially accounting for pitch irregularities while constraining radial movement between the two. If they work I might have to upgrade the mill! bla bla bla... pictures Just fits |
12-15-2013, 09:44 PM | #65 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Wow nicely done! I have ballscrews that have ballnuts with ~.0004" backlash so for me that is more than accurate enough! That being said mechanical backlash can be a huge issue when your doing climb cutting and it is not good for tools. I admire your diligence to detail on the machines. Did you ever cut oil slots in your mill saddle to allow direct "one shot oiling" like on a Bridgeport? I did that on my Hi Torque Mill and it works very nicely since I can inject a little oil and it is held in the pocket and keeps everything nicely sliding with no problems |
12-16-2013, 01:50 AM | #66 | |
Quarry Creeper Join Date: May 2009 Location: India
Example:- The diametrical position of the tool if shifts 10 microns on one side from the machines theorotical z axis centre line then when the tool rotates, the same error will multiply after 180 degree of rotation. So then, tool error will be 20 microns just spinning. Then add to this 20 microns, the ball screw error which will give us the final error value. | |
12-16-2013, 06:02 AM | #67 | |
Thanks | |
12-16-2013, 01:41 PM | #68 | |
Ballscrews I emailed the place and the guy said they had about .0004" backlash. I will get a photo up later of the part I made in stainless sheet with the screws. I was stunned Do note if you get the screws in their hardened state they are REALLY hard to cut! I never annealed mine since I was worried about bending them so I machined them hard on a HAAS SL-10 lathe and it did decently its just the inserts didn't enjoy interrupted cutting through hardened steel. past the outside skin it was relatively soft inside the screw. Last edited by Crawling Calvin; 12-16-2013 at 03:50 PM. | |
12-17-2013, 07:04 AM | #69 |
Cool site Too bad they don't have 10mm screws.
12-17-2013, 08:39 AM | #70 |
| Re: SMW Shop / My NEW Hobby |
12-19-2013, 10:13 PM | #71 |
Not sure if you have read this or not but its pretty informative Machine Tools: Lathe CNC Home The guy who runs the site does some sweet conversion stuff so read up. Could help |
12-21-2013, 11:44 PM | #72 |
Good stuff guys! Re-wiring day on the mill tomorrow, adding a cnc'ed 4th axis into the mix as well. |
12-22-2013, 05:22 AM | #73 |
Seems like the rotary table already had a flat machined on it when you bought it. What brand and what model is the rotary table? looks good to me. Nice to have a collet chuck. |
12-22-2013, 07:18 AM | #74 |
It was converted from a manual as well. http://www.use-enco.com/CGI/INSRIT?P...PMPXNO=4841009 You only have to make one permanent mod which is cut the end of the input shaft off to mount the coupling. Lol, no turning back now. I bought the 5c chuck when I turned the ends of my ball screws for the mill. http://littlemachineshop.com/product...ProductID=3047 Lots of adapting going on but the rotary and lathe are completely interchangeable as far as chucks go. |
12-22-2013, 09:21 AM | #75 |
Thanks for the links. For the adapter plate, what makes it cocentric to the rotary table axis? Is there a shaft from the adapter plate that enters the rotary tables centre bore? |
12-22-2013, 06:40 PM | #76 |
This is going to get interesting! I'm thinking a custom set of drivers is in order. Video... http://static.photobucket.com/player...psb4ea3e2a.mp4 Sorry for the crude links, posting via my phone... |
12-22-2013, 07:12 PM | #77 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
Pretty cool shit dude.
12-22-2013, 07:51 PM | #78 |
Keeps me out of the bars...
12-23-2013, 09:57 AM | #79 |
Slick! I'd love to get a 4th axis some day. Did you make the plate that attaches the 5C collet chuck to the rotary table?
12-23-2013, 12:19 PM | #80 | ||
SMW Shop / My NEW Hobby - Similar Threads | ||||
Worst hobby shop in town! Franks Hobby hell hole | bolibruch1 | Arizona | 26 | 10-07-2014 06:46 PM |
Hobby shop | 91Bluestreak | Michigan | 3 | 12-21-2011 11:56 AM |
what a hobby shop can do for you? | tubeman | Florida | 5 | 09-24-2008 06:23 PM |
