08-09-2018, 11:24 PM | #1 |
| Calculating spur gear diameters Make a copy or download an excel file to use. I made this so that I could find the largest spur to fit in a certain car, so that I could increase my gear reduction for crawling by switching from 32p gears to 48p gears but keeping a smaller pinion. For example I knew a 51mm spur would fit on my ax10 transmission with extended output shaft but I needed to know how many teeth that was at a certain pitch. I had a link to a calculator that did this, but I think it has been taken offline cause I can't find it now. |
09-10-2018, 08:24 PM | #2 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: Calculating spur gear diameters
So far my spur still in stock size 56T. Just bought an extended output for my next project. I am so far 100% happy with the 10mm extended output https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Sent from my iPad using Tapatalk |
09-10-2018, 09:05 PM | #3 |
Rock Crawler Join Date: Nov 2014 Location: Dells
It was taken down but he has the code posted for download Speed Calculator - Page 67 - RC-Monster Forums |
09-11-2018, 03:54 AM | #4 | ||
| Re: Calculating spur gear diameters Quote:
Calculating spur gear diameters - Similar Threads | ||||
Is there a metal upgrade gear for the 80T spur gear? | maddogs1965 | Axial Wraith | 9 | 03-25-2014 11:31 AM |
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
gear ratio calculating | Bknight | General Crawlers | 7 | 08-10-2006 09:24 PM |
Calculating gear ratios | tkruger | General Crawlers | 6 | 06-07-2006 01:03 AM |
Calculating gear ratio question | rcracer | General Crawlers | 4 | 06-03-2004 12:00 PM |
